THE LOUNGE 3...
RE: THE LOUNGE 3...
Was happy to find out that my folding knife is at home.. I thought I lost it somehow, but I guess during one of the moves, some of my stuff was moved to my sister's place.. !!
It is a CRKT M16-14M.. it looks like this..
RE: THE LOUNGE 3...
ORIGINAL: Lunchboxer
RE: THE LOUNGE 3...
Nice.. yeah, I bought it years ago.. and thought I lost it (I moved around a bit..) but saw it at home when my mom showed it to me... she said it was in one of the boxes that has my stuff but got moved to my sister's place..
NICE!!
NICE!!
RE: THE LOUNGE 3...
So you have 2 sets of stock rims? Or you mount the snow tires on the stock rims and swap out the summer tires?
Banned
RE: THE LOUNGE 3...
I thought I would share another one of my "criminally insane scientist" ideas with you today...
RC Turbo Boost
I haven't figured out all the details or if it can even be done, but here is the idea in a Homer Simpson Brain-Shaped Nutshell: Make a DC to DC Boost Converter that is controlled by an unused channel of the radio
Just imagine a 2s LiPo VW Bettle going at full throttle and along comes someone else next to you at about 3/4 throttle. They see that you are at full throttle and want to make it look like they are passing you on the highway so they start to speed up. You move your thumb over just a bit to the 3rd channel button and all of a sudden you have gone from 2s to 3s, 4s, even up to 5s LiPo speeds leaving them far behind [X(]
The only down side would be that it would have to act like NOS - burst of power for short period of time.
RC Turbo Boost
IL
RE: THE LOUNGE 3...
Didn't LB do something like this with NiMh, having an extra cell hanging in there he could go all NAWS on if he flipped a switch? Fun idea!
IL
RE: THE LOUNGE 3...
Took apart (in chunks) the Stadium Thunder the other day, gave it a simple green bath, and put it back together last night. All clean now!
1 down, 3 to go. [:@]
RE: THE LOUNGE 3...
ORIGINAL: Eman77
RE: THE LOUNGE 3...
Nope.. mine is on at all time... just an easy way to add voltage to the battery pack.. add 1 cell or 2 cell, etc. You just connect the extra cells in series..
ORIGINAL: Eman77
RE: THE LOUNGE 3...
Yes, I'm gonna make you find out the hard way. Yes, I'm brave.
They call me LB. Got a last name too, but I can't pronounce it.
End Scene...
ORIGINAL: secretsg
Do you have 100K under the hood of your S2K? [:-]
RE: THE LOUNGE 3...
That's an interesting idea.. would probably work on a nitro engine? Use a BL motor to drive a supercharger setup.. ?!
For electric car, I don't see how you can do it.. I mean, I am not sure how do you get the extra voltage.. other than strap on more batteries.. in that case.. you can just hook it up at the beginning and run it 4S / 5S to begin with.. and when you want to drive slow, just drive it part throttle...
Let us know what you come up with, though.. !!
ORIGINAL: Chuck Finley
I thought I would share another one of my ''criminally insane scientist'' ideas with you today...
RC Turbo Boost
RC Turbo Boost
CA
RE: THE LOUNGE 3...
Anyone see the Top Gear (History Channel one) with "The Stig" driving a TRACTOR around the track at 15 MPH, that was great my family was dying laughing, good stuff.
And im back been out for a while due to another leg surgery but im cranking out parts for my crawler out on my Sherline mill so what can i say! All's well in the world that ends well right
Banned
RE: THE LOUNGE 3...
Normally boost converters are used when there is constant power (think wall outlet or running car) and what that will do is take the starting DC voltage (12v for simplicity) and then raise it x amount - say 24v.
If you ever see one of those laptop charging things that plug into the cigarette lighter, same exact thing...
Google search broght me to this: [link=http://projects.dimension-x.net/archives/79]TPS61040 Constant Current Driver[/link] [X(]
RE: THE LOUNGE 3...
[link=http://www.imgburn.com/]ImgBurn[/link] - used to turn CD / DVD into an *.ISO file.
[link=http://www.daemon-tools.cc/eng/home]Daemon-Tools[/link] - used to emulate a CD / DVD Drive.
RE: THE LOUNGE 3...
ORIGINAL: Eman77
A 10 cell Nimh pack would be hard to make, especially to get it to fit the car right.
Most 7 cell packs you see these days have the extra cell on top of the pack to fit it in a chassis.
RE: THE LOUNGE 3...
Yeah, but when you up the voltage, from the same battery, you'd lower the current draw.. so it doesn't really work.. (there's no free lunch.. no free energy there..) Meaning that if your battery can support that voltage and current, then you can run a hotter motor to get the same performance w/ lower voltage.. But without the loss in efficiency during the conversion..
[link=http://en.wikipedia.org/wiki/Boost_converter]Boost Converter[/link]
Banned
RE: THE LOUNGE 3...
The boost would be just that - a boost. Think NOS It wouldn't be a replacement for putting in a bigger battery.
It is just one of those randon thoughts that goes through my mind when reading or doing something electronics related.
Many have failed without trying. I want to fail after trying [X(]
RE: THE LOUNGE 3...
Yeah, I hear you... Keep us posted!
My point was simply that if you can convert the voltage to be higher and get more performance out of that battery, you are simply not running a hot enough motor... Any sort of conversion will only result in loss due to efficiency..
But, would be cool, if you can change the voltage on the fly and upmthe performance of a slower motor...
