Anyone got a 95 Cutlass Supreme Coupe!
Well i had a 97' Explorer V8 and i loved that thing to pieces but one day me and my buddies were doing some dumb @#%@ and it was hydrolocked. Now i have a black 95 cutlass supreme coupe. Imean i paid 1500 for it and so you can expect its what is for that cheap. I wanted to not spend much tho because money is tight and i need it for college. Anyways just to make me feel better about the wheels im driving i just want to hear if any of you have anything good to say about this car...
RE: Anyone got a 95 Cutlass Supreme Coupe!
what engine? olds are known for bad lines and the 3.4 is known for busting rockers, but other than that they are not too bad. (better than a exploder IMO)
ORIGINAL: lee172
pics man! you know the drill!
OH
ORIGINAL: The_Shark
You realize the 3.4 in those cars are DOHC right?
And what's wrong with the Explorers? Had a '98 and an '01 Explorer, both 5.0s, were awesome trucks.
I have a '96 Olds Ciera. Completely different car of course, but they do share some parts and both are Oldsmobiles.
Here's my Olds:
Not that cool, I know, but it was only $600, has brand new brakes and front tires, and runs perfect.
Here's my Olds:
ORIGINAL: ThunderbirdJunkie
Rockers you say?
ORIGINAL: The_Shark
later model explorers arent too bad, but the 6cyl and autos sucked on the earlier ones, chains going out at 80k autos that never shift out of third and just shoddy interior and blend door problems.
NJ
Cologne V6 did all it needed to and I never had any shifting problems with my 1994 'sploder. Interior was fine by me. I just wish it wasn't crashed into. []
OH
ORIGINAL: The_Shark
dont those have the pushrod 3.4 also? i thought only the aurora used the DOHC v8 and v6.
Rockers you say?
ORIGINAL: The_Shark
You need to start educating yourself before making crap up dude. ThunderbirdJunkie has probably owned more GM 2.8s, 3.1s, 3.4s, etc than you've worked on and he's never even HEARD of a "rocker problem" in the 60 degree GM V6.
Never seen a timing chain issue out of an SOHC 4.0 Explorer that was properly maintained. People that do 10,000 mile oil change intervals are the only ones that have issues out of those engines before 200,000 miles. Have you ever actually done a timing chain job on an SOHC 4.0 Ford V6? Betting no.
The 1st gen Aurora ONLY had a 4.0L version of the Northstar V8. The 2nd generation had a 3.5 liter V6 version of the Northstar V8 as well as the 4.0.
Both are good engines.
ohh tbj.
note if im not positive i say think, or believe or heard. also i have seen 3 3400 and 1 3100 that bust rockers that come in with a really loud "knock" and kick the engine around. i have seen 2 4.0's with bad chains, one busted as it was being brought in. no i never did a chain job, book time is around 13 hours or so and Ford suggest to install a new engine as a broken or slipped chain results in top end engine damage.
GM makes (or buys) decent DOHC engines, however the northstar has problems with the oil pan leaking, and usually is never a cheap job.
ORIGINAL: HJJFFFAA
Looks to be in pretty good condition for 600 bucks.
x over 9000, awesome, bulletproof cars.
ThunderbirdJunkie is envious of mech's ride.
Overall shape is good, a few cosmetic defects here and there, and rear fender rust of course, but I'm very happy with it. Smooth ride too, it's like riding on a magic carpet with loveseat on top.
OH
ORIGINAL: The_Shark
ohh tbj.
note if im not positive i say think, or believe or heard. also i have seen 3 3400 and 1 3100 that bust rockers that come in with a really loud ''knock'' and kick the engine around. i have seen 2 4.0's with bad chains, one busted as it was being brought in. no i never did a chain job, book time is around 13 hours or so and Ford suggest to install a new engine as a broken or slipped chain results in top end engine damage.
ohh tbj.
But, here goes anyway.
GM has always been at the top of the DOHC game. The 2.3 liter 180 hp Quad4 in the late 80s before Honda could build a V6 to match that power using the VTEC crutch, the 385 hp and 405 hp LT5 engines, the 214 hp DOHC 3.4 that outpowered Honda and Toyota's variable valve timing V6s until the early 2000's when the engine had been discontinued for 5 or 6 years, the Northstar with its unmatched longevity (YES, LONGEVITY, despite being a PITA to change the starter on) and 300 horsepower to boot.
How about the Cosworth Vega? 110 hp, twin cam 2 liter I4 in the mid '70s. Ford's 302 was only making another 10 horses.
yes, i knew GM has made DOHC engines for a time, most models are pushrod, nothing wrong with that.
opel-gm did make a 3.0 engine for a saturn and the eco tech is saab based which isnt too bad.
i think they should bring back the Quad-4, yes it had its issues but it was high output and imagine what can be accomplished with today's varible cam systems.
NJ
ORIGINAL: The_Shark
ORIGINAL: HJJFFFAA
I call it, Ecotec.
ORIGINAL: The_Shark
NJ
ORIGINAL: The_Shark
how much is the damage grammar cop?
ORIGINAL: HJJFFFAA
I call it, Ecotec.
ORIGINAL: The_Shark
scratch that, i did some digging, thanks to the net ive heard that its opel based, lotus based and saab based, but all are a branch of GM-Europe. supposedly it was first used on lotus, and first designs where from the 70's.
actually both ford and GM (and recently mopar) have unique designs in europe, the G-8, festiva, (i belive the malibu) and soon the cruze, its hard to tell if designs are from the US or if they are exclusively european.
you can go on and nit-pick all you like, i used to be a textbook, that was before i had a job and went to collage, so all i go on is memories, prove me wrong and i will agree, i will not argue the truth, however there is a wrong way and right way to correct someone, and that you cannot look up.
OH
Lotus did the majority of the design work on the Ecotec
The only thing Saab did with the Ecotec is work in direct injection on the earlier turbo models for their own cars.
