RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Off Topic Forum - Cars, Trucks, Buggies and more (http://www.rcuniverse.com/forum/off-topic-forum-cars-trucks-buggies-more-392/)
-   -   Weed eater engine problem. (http://www.rcuniverse.com/forum/off-topic-forum-cars-trucks-buggies-more-392/7316108-weed-eater-engine-problem.html)
JB COMP 04-01-2008 10:19 AM
Okay this is probably not the right place for this but, I have a john deer weed eater (or whacker what ever you call them) that dosen't have a spark to the plug (and it has a new plug in it) what should a do to figure out what the problem is?
-EXTRA- 04-01-2008 11:26 AM
RE: Weed eater engine problem.
ORIGINAL: JB COMP
Are you holding it to the engine block?it wont spark unless you do..otherwise sound's like the coil is bad.
JB COMP 04-01-2008 03:57 PM
Yeah, the plug is sitting on the head.
sheograth 04-01-2008 04:02 PM
Sounds like a coil problem. Also check to make sure the kill switch (if it has one) isnt sticking.
JB COMP 04-09-2008 02:48 PM
Anyone know where I can get a PDF manual for it? Its a John deer 21S.
annie_himself 04-09-2008 03:30 PM
Go on the website.
JB COMP 04-09-2008 03:41 PM
They want like $50 for a CD manual[X(]
Toki 04-09-2008 03:45 PM
Condencer?
JB COMP 04-09-2008 04:13 PM
ORIGINAL: Toki
Condencer?
[sm=confused.gif] what?
Toki 04-09-2008 04:28 PM
The condenser is prolly bad. i do not know much about 2 stroke weed eater motors. but i do know 4 stroke lawn mower engines 99.9% of the time if the plug is good it is the condenser that is bad on those engines.
JB COMP 04-09-2008 05:02 PM
ORIGINAL: Toki
is that the same as the coil?
There's no condenser on this engine.
http://jdpc.deere.com/pimages/MP13/M..._UN09SEP94.gif
I think 4 is what went out on it.
Toki 04-09-2008 05:22 PM
yes it would be #4 that i would say is bad. i would say put a volt meter on the plug wire and spin the motor buy hand you should get a spike in voltage if not then that would be my guess is #4. i mostly work old 4 stroke and if their is no spark it is points and or condensor i would imagine that is all in part four done electronicly.
sheograth 04-09-2008 05:35 PM
Condenser is an antiquated term for capacitor.
JB COMP 04-09-2008 05:54 PM
anyone know what it should cost? (just a guess. I'm guessing $20)
Toki 04-09-2008 05:56 PM
i do not think it would be to much prolly around that. i am sure it is a comon part.
Toki 04-09-2008 06:02 PM
JB i believe the part you need is called a Module--Ignition looks like they run about 20-25 bucks and come with a plug wire.
Toki 04-09-2008 06:03 PM
sorry one more thing remember to put a meter on it to make sure that is the part you need.
JB COMP 04-09-2008 06:06 PM
This is what they call it- 4 M112518 ELECTRICAL COIL 1 010001 - 075000
The_Shark 04-09-2008 06:19 PM
in the automotive field we call it a spark coil or ignition coil.
very very easy to replace.
most weed wackers i garbage pick (hey theres something with a motor on it!) usually are thrown away because of a bad coil or cracked hoseing.
JB COMP 04-09-2008 09:38 PM
ORIGINAL: The_Shark
This on was given to me because they didn't want to mess with it, and they also gave my Dad a Ryobi 857R that I think needs the carb rebuilt and the attachment.
calvino 04-09-2008 10:06 PM
amazing what people will throw out due to a minor problem, you can also try taking the plug out of the engine (grounding what needs to be grounded), and pulling the cord in the dark and seeing if you can get a spark from it
iamnot 04-09-2008 10:17 PM
ORIGINAL: calvino
he's already past that point
see post #3
there is no spark
if the coil is not bad, which it probably is
the only other thing i can think of would be a ground / kill switch wire that is shorting out
-EXTRA- 04-09-2008 10:47 PM
There 15-20$ and is very easy to replace.already come with pre attatched plug wire's,doesn't get any easier.
SAVAGEJIM 04-09-2008 11:45 PM
ORIGINAL: Toki
Condencer?
LOL, you make it sounld like this is HVAC, the condensor on a heat pump (AC for most purposes, but in America, what they refer to a "heat pump" is an AC that can pump heat from inside to outside but also be reverserd to pump heat from outside into the house).
Yes, this is the coil that you are talking about, the #4 in the parts pic that was posted.
Toki 04-10-2008 01:02 AM
Savagejim
no i do not make it sound like A/C what i said was i do not know much about 2 stroke i do know 4 stroke lawn mower engines and guess what. they have a condensor. a coil is used on a car engine not a small engine. A small engine uses a condencer well atleast old ones (thay may have changed the name). that is why this showed up after i wrote that ? so no this is not A/C you are right about that. i was just trying to help the guy out. he had a problem and i knew something well a little about the subject and it seems we got further to figuring it out. you added nothing to solution at all.
old 4 strokes also have points and no i am not talking about Multiple point calibrated HVAC flow rate controller or optimal set-points synthesis for HVAC or technical points of view with most HVAC systems. i am simply talking about the points on a 4 stroke engine in amarica.
