Razor Yak engine?
My Feedback: (13)
NJ
Razor Yak engine?
Would the Razor Yak work WELL with a saito 91? I dont want it to struggle. According to my "calculations", the engine should put out 11lbs of thrust.
What do you guys thinks?
My Feedback: (13)
NJ
RE: Razor Yak engine?
ORIGINAL: DenverJayhawk
how well will an OS95AX work on this model? Enough engine for stupid pullout power at Colorado elevations (5280 ft)?
Correct me if im mistaken
My Feedback: (57)
IN
If it were me at a mile high, I'd go with a YS110, or a 120AX or Saito 125. If you don't already have an engine, that's where I'd start.
The 120AX is only an ounce more than the 95 and if you want stupid power, there it is.
Just keep in mind that weight is just as important at high altitude as having enough power.
The airframe acts like is has less wing area along with being heavier.
