47" Edge V3 New Batch!!!
#177
RE: 47" Edge V3 New Batch!!!
I'm using an OS 55AX on my V3 that dead sticked on me last weekend. Im in SC and its HOT so I figured it must be running rich. So today I tried tweaking the l/s and h/s needles. I have a 13x4 prop, it idles @ 2400 rpm and maxes at 10,400 rpm. There is a slight hesitation from idle to flat out. After 2 tanks of fuel I have a large wet spot from exhaust and the motor is still hot to the touch after 3-4 min. Does this sound right? close? back up and punt? thanks for any help..
#178
ORIGINAL: Avalanche2
Im also using the HS-81 with an O.S.55 AX and the throttle worked out fine.. heres and over head of mine... the V3 is ready for run in... the plane sure looks nice... thanks for the help all...
A word of caution with the HS 81. Although a great little servo it does not have output shaft bearings and the shaft is directly connected to the potentiometer. Good for electric use but takes a beating when used for high vibration environments like glow throttles. It will work but has a limited life. Better to use the HS 85 or HS 85MG.
#179
CA
I may have missed this - but what is the differences between the V3 and the previous versions
and can/should an unbuilt kit be retrofitted - thanks
p.s. is there an eta on more 540 v3 arf/kit
#180
ORIGINAL: JRC
ETA is hard to say as I still have no hard evidence of the shipping status. Only verbal that the container has left China. Typically I would expect product in hand 4 weeks from that point.
#181
Im having some dead stick issues with my OS 55AX.. can anyone flying one of these tell me the set up they have... rpms, low speed needle setting, h/speed setting... Ive checked all I know to check.. clunk/line is good,tank pressure ect.... sure is a blast to fly, would hate to hear silence about 10 ft off the deck... any help is appreciated..
#183
I use the stock OS plug and Cooper 10% fuel. Never had any problems. Had the stock muffler on but switched recently to the Tower Hobbies muffler and runs just as well. Flew the snot out of it this past weekend up at the Bryan Pro Bro event.
#184
Im using Cool Power 15% w/ stock plug swinging a 13x4 prop... I think my last tach. reading was around 9400... It idles great, transitions good... ???? Im lost...
#185
FL
Hello all, I just won this plane at the FX3D and have it outfitted with an OS 55AX, Question, what is the best prop for 3D practice. Don't want it too fast but not too slow either as i am still learning 3d stuff?
#186
Xoar - 13 x 4
APC - 13 x 4W
APC - 13 x 4
I like the Xoar the best, but they break easy. Get one of the APC's and you should be fine.
J.
APC - 13 x 4W
APC - 13 x 4
J.
#188
Isn't anyone using the Saito 82 anymore? All I see is the talk of the 55AX which I know works great, but I have a spare Saito 82 sitting here.
With the Saito vs. the 55AX, would there be much difference in acheiving the correct CG?
Ernie
Ernie
#189
TX
I started out with a 55AX, then switched to a Saito 82 to see what the difference would be. I switched back to the 55AX because the plane became too nose heavy, and that's with the 82 al the way back in the mount.
RFan
RFan
#191
CA
ORIGINAL: rfan_1
RFan
RFan
#192
My Feedback: (13)
NE
I am considering buying a profile, more specifically an OMP product (either the Edge or ProYak). I have not had a profile before and was wondering how they handle the wind. Also, does wind make them a challenge to land?
#194
My Feedback: (13)
NE
ORIGINAL: The Toolman
Go look at my post over in the omp edge 540 folder you posted in
Ron
Ron
#195
I'll repeat my response here:
Flying the OMP Edge or ProYak in the wind is easy and actually a lot of fun. They handle the wing exceptionally well and honestly one of my top choices to fly when it is really windy. Doing rollers or HAKE stationary over the runway is a blast. Landings are also fun as you can float straight down onto the landing gear with zero ground speed.
