Need Info on servos
IA
Need Info on servos
Good day
I have never been around anything that needs four servos on the rear. How do they work? Do you have to do anything trick ? Curious as they install on both sides. I have a x3d 52 fusion. Curious as to how its done???
TX
RE: Need Info on servos
There are a few ways to run multiple servos to one control surface. I like to use a Smartfly Equalizer 2. You simply plug the Equalizer into one of your receiver channels and two servos into the Equalizer. The Equalizer allows you to synchronize the servos by matching their end points. It will also allow you to reverse an individual servo if necessary.
http://www.smart-fly.com/Products/Eq.../equalizer.htm
IA
ORIGINAL: daveopam
The 52" Fusion only has two servos in the tail. One for rudder one for elev. Did I missread your question or are you talking about a different plane?
David
David
Well I guess I kind of wondered about that. The instructions and the pics are pretty sparse and every pic I saw looked like there was two on each side of the tail. There is no instructions that tell how many. And there are spots on both side of the fuse for them. But you sure made it a lot easier to put together. Thank you
Mike
Mike,
Hope you have it figured out. The pics in the manual show the typical tail servo installation. One elevator and one rudder servo is what is required. Pretty much standard setup on every 40 size profile on the market these days. Obviously being a profile the servos will stick through both sides of the fuse so that is probably what is confusing you.
IA
Thanks you guys I needed that. I am red faced as a little common sense would have gone a long ways here. This is the first profile since probably 1975 and those were cl planes. Gettin old I guess.
IA
ORIGINAL: AFSalmon
The OS 70 4S should be plenty of power for the 40 size profiles. I've never run that engine but I would assume it would require 20% nitro to be any good.
Why 20%? Are they that pouchy? Better to use OS FXI 46? What size prop for both? Not going to do 3d.
This is just pretty much what everyone says regarding the 4s engines. I know my Saito 100 runs very poorly on 10% nitro. I use 20% and it runs much smoother and more reliably.....plus better power. There are many threads on fuel and tuning for the 4s engines. I have never run an OS 4s so am only speaking from reference.
