Woody extra
My Feedback: (16)
IL
RE: Woody extra
ORIGINAL: jdan
What CG are you using ? Thanks
I also haven't measured the AUW cause I lost my digi fishing scale (overboard due to a rambunctious catfish). I do know the plane could stand to be built about 6oz or so lighter. There's some beautiful work in the joints but it's a little over-engineered, IMHO. That said, my 82 on 30% swinging a 15x4 Xoar yanks it around and hovers at about 1/2 throttle with plenty of (if not ballistic) pullout.
If you get some wingrock on upright harriers, add some flaperon to it. I usually need to add spoileron to my planes but the Woody smooths out beautifully with about 7-10 degrees of flaps. I set that to a switch and can drive it around the field with its tail in the high grass with the best of my slabs.
Mike and Frank, is the wing tube with the plane supposed to be short? Mine is about 2" or so too short. I checked the stops in the outer wing tube and they're right where they should be, the CF tube just doesn't go from stop to stop when the wings are on. Still holds up well, though. Just a little odd.
I have to admit, even with the things I think could be done a bit better (or simpler) with the plane, I do love flying it.
My Feedback: (16)
IL
RE: Woody extra
ORIGINAL: AFSalmon
Bill, I never noticed the wing tube being short but can't recall sliding it all the way in and measuring both sides so it might be.
