yak 55 elevator
yak 55 elevator
can someone tell me if i have to cut the elevator in half to put the jointer in?the plans show it in but wht does it have a 1/4' leading edge all the way acrossed it
RE: yak 55 elevator
ORIGINAL: edge540l
Your question doesn't make sense Rob. You don't cut the elevators in half. They are built as shown over the plans and joined with the supplied 1/8" wire joiner. There is no 1/4" leading edge all the way across. There is 1/4" balsa triangle stock glued to the leading edges of both which serves as your hinge stock.
RE: yak 55 elevator
the plans show a 3/4 sq balsa leading edge as well as the triangle stock the legnth of the elevator as well as the jointer wire,on pg7 you have posted pics of it the way i built it,so do i cut the 3/4 balsa then put in the jointer wire??
RE: yak 55 elevator
Rob, there is no 3/4" sq balsa on the leading edge of the elevators. The elevators are only 3/8 thick. The leading edge parts are laser cut and the hinge stock is 1/4" triangle stock. The plans are correct here. The picture in the manual was actually from a previous stick built version using a 3/8" sq balsa leading edge. Both were built together and then yes, cut apart before installing with the wire rod. I think you have the idea though.
