OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Fusion 80 Question
Old 02-17-2009, 09:47 PM
Uncas
Default Fusion 80 Question
I will be mounting my throttle servo near the top instead of the bottom to match my engine. In other words about 3 1/4 inches higher. Is there a problem with routing a second servo wireway channel from that location straight into the wing area cut out? Is there an area I should not put the wireway?
Old 02-18-2009, 10:14 AM
AFSalmon
AFSalmon's Avatar
Default RE: Fusion 80 Question
ORIGINAL: Uncas
Absolutely not. The fuse being foam core and sheeted gives you plenty of options. Try to plan your mod before sheeting the fuse so you can pre-cut your new channels.
Mike
