GS540 ARF Questions
I am thinking about buying a giant scale profile- I am wondering what is the preferred set up for the gs540 arf- What engine is recommended? I am trying to figure out a rough cost so that I can see if it is feasable for me to get one- any information will be greatly appreciated- Is the gs540 arf still available???
Thanks- Alex Holden Pro-Bro #555 [email protected] 828-719-8395 |
RE: GS540 ARF Questions
Yes the ARF is still available, but this run is going fast. The next batch will be in over a month. We recommend an OS 1.60 as a good starting motor, that is what we have on the very first ARF in the video on our website. Then you can basically can go up as high as you want. We have seen all the way up to DA 50. We are also working a deal with OS so that we can sell you that OS 1.60 for less then you can get it at Tower which would be less then $249.
so when can I get the engine at that deal???? I would probably order one right away.........
thanks Alex |
Right now. I don't have the option to purchase the OS 1.60 online. But I can get it for you. Plus we can put the engine in the ARF box, however you will not get your OS box. If you want the OS 1.60 box we will ship you the OS 1.60 separately for $7.
Let me know and I will arrange it for you. |
can you email me a quote for the ARF and engine and also the complete tuned pipe assembly???? thanks
alex holden pro bro #555 [email protected] ps- can you not break the engine box down flat and put it in there???? also what servos do you suggest on a gs plane like this one???? I prefer Futaba- thanks for all your help- |
Its up on the website right now! Front page.
sweet..... I'm going to get one- thanks for the help-
alex |
I dont have the order mechanism up yet. You can contact me direct.
What servos do you reccomend for this plane???? Would the Hi-tec hs5625mg be a good choice??? what about the throttle servo???? thanks in advance
Alex |
I have 5625's on my kit version. They are plenty fine! I use a standard on my throttle.
great! that's what I'll use then......... with a 6v battery for a little more torque- thanks
Alex |
Yip ... 6 volt here as well!
