Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Mini Telemaster
Reply
Old 04-21-2011, 05:23 AM
warbird_1
My Feedback: (61)
warbird_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mini Telemaster
i've been flying for over 27 years. gezzzz that makes me sound old ! i really learned to fly on a telemaster .40 though i have moved onto jets and giant scale warbirds , i have always owned a t-master.
i now have a t-master 40 and a mini t-master for cruising around at dusk. i also just picked up a set of plans for the 12' version yee haa ! anyways ... the mini is a big disappointment. it fly's like crap !
it doesn't have ailerons and i know they make a replacement that does but i was wondering it anyone else thinks it fly's bad. it only has the rudder so i'm thinking it doesn't have enough dihedral in the wing. any thoughts?
the pic is of my scratch built .40
warbird_1 is offline
Old 04-22-2011, 07:47 AM
Tommygun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mini Telemaster
If the mini has the same amount of dihedral as the one in the picture, than I'd say it definitely needs ailerons. Are you using quality, lightweight gear appropriate for that size plane? Did you use light balsa/use glue sparingly? Sounds like it may have come out on the heavy side.
Tommygun is offline
Old 04-22-2011, 08:04 AM
warbird_1
My Feedback: (61)
warbird_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
t-master pictured had most of the dihedral removed. mini is not very heavy just control issues.
Old 04-22-2011, 09:00 PM
jdetray
jdetray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most planes without ailerons require a certain amount of dihedral in order to turn properly. If you removed most of the dihedral, that is most likely why the plane doesn't fly very well. Either add ailerons or restore the recommended dihedral.
- Jeff
jdetray is offline
Contact Us Archive Advertising Cookie Policy
