Go Back  RCU Forums > Electric Aircraft Universe > Park Flyers & Backyard Flyers
Reload this Page >
New 20mm EPP WWII Series, ME-109 and P-51
Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Old 06-15-2011, 10:45 AM
2dogrc
Default New 20mm EPP WWII Series, ME-109 and P-51
We have just received in a new shipment of Techone planes, a Me-109 and P-51. These 2 planes both have a wingspan of 33" and a length of of about 27". The best part about these planes are that they are easy to build and can take alot of abuse. The 20mm thick EPP is reinforced by carbon fiber for extra strength.
[link]http://www.2dogrc.com/catalog/electric-planes/techone-warbirds[/link]Warbirds!!
Each plane is controlled by ailerons, rudder and elevator for a fully maneuverable flying machine! These would make perfect combat planes! Each plane also comes fully painted with a standoff scale scheme.
You will need to purchase electronics separate or use any 370 equivalent (150 Watt) motor for power. You will need 3 9 gram servos, or 2 6 and 1 9 gram depending on the torque of the servos. The holes are pre cut for mounting the servos. The battery bay is cut in the nose to help keep the CG right down the fuselage without any tendencies to pull one way or another.
I listed some specs below. The T-2208 motor is the same as the Tiger Motors sold by others and a decent stock setup. If you wanted some extra speed, but shorted flight try the Dualsky 2826-10 pusher jet motor or similar!
For more great planes check out [link]http://www.2dogrc.com[/link]www.2dogrc.com!
ID:	1623700   Click image for larger version
ID:	1623701   Click image for larger version
ID:	1623702   Click image for larger version
ID:	1623703   Click image for larger version
ID:	1623704   Click image for larger version
ID:	1623705   Click image for larger version
ID:	1623706   Click image for larger version
