Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
radio problem for newbie
Reply
Old 02-27-2012, 04:30 PM
bgordon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default radio problem for newbie
Im working on a new plane and following the instruction. New batteries in transmitter. Battery charged for plane. connect battery to esc and attach switch lead to receiver. Switch on transmitter and then switch on receiver. The first time I did this it worked fine. Now it will not work at all. Help!
bgordon is offline
Old 02-27-2012, 05:17 PM
Angel727
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: radio problem for newbie
Have you check the connector from the battery to the receiver? Check another receiver or if your receiver is one that's need to bind to the transmitter have you check that?
What transmitter and receiver are you talking about? Please give more info.
Angel727 is offline
Old 02-28-2012, 02:35 AM
fishycomics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you sure you are polarity Pos to pos, and not reversed? fonts are super small, and not in a wrong pin?
fishycomics is offline
Old 02-28-2012, 07:33 AM
bgordon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK radio is Futaba T4YF-2.4G.... ESC is SS-25 Brushless 5V/2A BEC....Battery is Electrifly BP 1250...1250mAh...11.1V 14Wh...receiver is Futaba R2004GF...I have tried to reverse the connection between the battery and switch...could I have ruined something. I bound the radio and receiver the first time as per instructions. If
bgordon is offline
Old 02-28-2012, 12:34 PM
proctor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't use Futaba, but suggest the following,
Bind again, remove bind plug, switch off receiver, then be sure to turn off transmitter.
Switch on transmitter, then switch on receiver. The thing to make sure is to turn off transmitter after
binding, this is essential with Spectrum not sure about Futaba.
Note the plugs and sockets on your gear is so designed that if you plug in the wrong way,
ie not pos to pos, neg to neg and signal to signal as it should be, you won't damage anything but of course
it won't work.
Good luck, I know how frustrating it can be at first. john
proctor is offline
Contact Us Archive Advertising Cookie Policy
