Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Can ANYONE answer this GWS Zero question???
Reply
Old 03-27-2012, 09:43 AM
ristst
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can ANYONE answer this GWS Zero question???
Hello all,
I've asked this question repeatedly at a few other forums and so far no answers. I'm hoping someone here can answer it.
I have a GWS Zero I got in '07, and just holding up the fuse and wing I can see clearly that this bird has the problem with the Angle of Incidence.
Rather than lower the AOI of the leading edge of the wing I'm considering lowering the trailing edge of the horizontal stab.
Has anyone done this, an anything remotely similar? Will it even work? If it's feasible then how much do I drop the stab? Same amount or some percentage?
If anyone can answer this, thanks in advance.
ristst is offline
Old 03-27-2012, 01:44 PM
ristst
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can ANYONE answer this GWS Zero question???
**SIGH**
20 views and no replies....more of the same.
Anyone care to chime in with a comment? *ANYTHING*...?
ristst is offline
Old 03-27-2012, 04:57 PM
mad web tv scientist
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try to give it a shot. As you have indicated, the horizontal stab must have some negative AOI relative to the wing. The tricky part is the experimentation in figuring out just how much and can it be trimed out in flight before crashing. It turns out that I am not very good at getting it right on maiden flights even with planes that are set up accurately. You might try searching for useful information on the web regarding basic aerodynamics. Maybe you could find a friend with a similar looking plane that could get get you close enough to enjoy a crash free maiden. It might help to use maximum expo and more than needed elevator deflection angles for the first flight. If the ship can be controled, land quickly over grass' and decrease expo and elevator deflection to something you can be comfortable with.
Let us know how you come out. Hope these ideas can help.
Out.
__________________________________________________ ___
FIGHTERS - AVIATION'S ULTIMATE CALL TO GLORY, HONOR, AND IMMORTALITY - http://community-2.webtv.net/RICHARD...4/CALLTOGLORY/
Spitfire Brotherhood #64 Post # 407 - Battle of Britain & Wiinston Churchill relevance to modeling
mad web tv scientist is offline
Old 03-27-2012, 05:22 PM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mad web tv scientist
I'll try to give it a shot. As you have indicated, the horizontal stab must have some negative AOI relative to the wing. The tricky part is the experimentation in figuring out just how much and can it be trimed out in flight before crashing. It turns out that I am not very good at getting it right on maiden flights even with planes that are set up accurately. You might try searching for useful information on the web regarding basic aerodynamics. Maybe you could find a friend with a similar looking plane that could get you close enough to enjoy a crash free maiden. It might help to use maximum expo and more than needed elevator deflection angles for the first flight. If the ship can be controled, land quickly over grass' and decrease expo and elevator deflection to something you can be comfortable with.
Out.
PS I don't know how this happened.
Old 03-27-2012, 05:27 PM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
deleted
Old 03-29-2012, 01:42 PM
soarhead-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had a couple of the GWS Zeros. As you know it was originaly power by the 300-350 geared motor and NICADs for battery. The plane flew decent for the day, but as brushless came around the positive incidence in the wing was a problem with the power available.
The way I and many others cured the problem was to sand the wing saddle down, actually up, about 1/8th of a inch from the high point of the airfoil to the trailing edge. This allowed the wing to twist so it pointed down taking out the too much positive incidence. Some did change the horizontal stab angle, but the sanding to me was the simplest and worked. It is a great flying little cheap foamy
Happy flying
Bob
soarhead-RCU is offline
Reply
Display Modes
