hitec radio/slow stick problem
hi have focus 3, the reciver on mount sticks up to high
for wing to be put on gws slow stick, have seen post of others
using the same reciever but no mention of this .
thanks
mike
thanks
mike
TN
I ran into this problem as well with a GWS R4P with vertical pins. It is hard to find anywhere else to place the receiver, unless you mount it forward of the front wing pylon. The best thing to do is simply buy another receiver, such as a GWS R4P receiver with HORIZONTAL pins (~$20). A Hitec Feather also has HORIZONTAL pins so if you'd rather stick with Hitec then get one of those.
Good luck, Cheers, Phil
CA
I had a different receiver, but with the same problem.
I glued a piece of 1/32 plywood to the side of the fuse stick (about the size of the reciever) and used velcro to attach the reciever to the ply.
Sierra Gold
Sierra Gold
hi ,read ideas and decided to silicone reciver to plastic sheet then
silicone sheet to boom after getting cg set ,that way its shock mounted and can easily slice off silicone if i need to move it
slight mod of ply idea
thanks
mike
thanks
mike
