Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
1400mm j3 cub
Old 03-05-2013, 07:58 AM
My Gallery
My Models
My Feedback
Default 1400mm j3 cub
This PNF Cub is remarkably scale for it's size, is easy to fly and being a bit bigger can handle more wind .A real favourite with scale pilots, this is a Cub you will be proud to own
quick assembly and almost every component is attached by screws, including the 2 wing halves, even the tailplane can be removed for transportation if desired. All servos are pre-installed as is the ointer">ESC & powerful Brushless Motor. This model is ideal for RC pilots of all ability and it is not often that a geniuine scale model can be flown by relative beginners. The scale detail is quite amazing, plastic injection moulded parts are used extensively and include the dummy engine, wing struts and and the dummy bungee under-carriage.
Practical features include the linked steerable tailwheel, large magnetic battery hatch, construction of course from tough & easy to repair ointer">EPO foam, large "Cub" wheels with rubber tyres and 4s power for guaranteed performance.....a fantastic looking model on the ground and in the air.
Length: 950mm
Flying Weight: 1800g
Wing Loading: 56g/dm2
Motor: 36-48 700ointer">kv Brushless ointer">Outrunner
ointer">ESC: 45A w/BEC
Prop: 12x9
Servo: 9g x 4
All Hardware
Colour Photo Instruction Book
Your Own 4 Channel TX/ointer">RX
maverick602 is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
