Scratch built T-6 Texan
After reading about blue foam on another forum I had to try it out.
I bought the blue fan fold foam from Home Depot.
I had an old set of plans for an Ace simple T-6 and here you have it. The wing is 36" around 200 SQ " . Power a GWS 280 geared motor with a 10x4.7 prop.
As of now it weighs 10.5 oz's with the flight gear and a LiOn 2 cell pack. I wanted a full house so I have Ali,Rud, and ele for controlls.
Im not to the point of flying it yet but hope to be done soon.
If it flys I will paint it yellow and red. Happy flying John
Thanks for the reply
Thanks Klink
It's not expensive if you already have the radio gear. I paid $10.99 for the 280 motor. And ended up with all of this fom for $23.99. This is what is left after the plane was built. I think I used a 1 to 2 sheets of the stuff and a hot glue gun. John
thats just to cool
make sure ya take some pix when she's painted
i just got a flyzone spitfire
free flight electric
im stuffin a radio in it now
gotta tinker
gotta tinker
Need more power
Thanks for the replys guys.
Well I test flew the T-6 today or tried to anyway not enough power. With some uptrim and a toss at WOT it glided 30 feet and landed level. Just not enough power. I tried the geared 280 2.8.1 and a 10x4.7 no good. Also the same with an 8x6 same thing. I think it needs the same motor that the GWS zero has .
The zero uses a geared 370 with a 10x8 prop. Looks like that will be my next purchas. Now I have to figure what size the plane needs to be to fly with the IPS system and build on of those.So I can use my Qualcom packs with it .
I cut out the plans from an old ace simple AT-6 kit.
Then just use an exato knife after tracing the templit . I used a hot glue gun and also some superbond kind of like industreal elmers glue. I bought the foam and got around 26 sheets for $23.00 I used 2 1/2 sheets so you can see it can be very cheep but labor intensive.
John
John
Should recive my new motor in a couple of days
Well I ordered
1 - GWS EPS-300C (CS) @ $16.45
3 - GWS Slow Flyer Propeller EP1080 @ $2.15
1 - GWS ICS-400 ESC (Futaba) @ $29.95
1 - GWS 7-Cell 350 mAH Ni-Cd Pack (8.4 V) with JST Connector @ $9.95
Totals:
Sub-total: $62.80
Shipping: $5.95
Tax: $0.00
Order Total: $68.75
Hope this does the job it fly's the GWS Zero well so I'll give it a try . Wanted to stay with the 280 becaws I already have a 5amp speed controller. Well baring a major crash I can use this in other stuff. Will keep all posted with the flight results . Seems as if GWS is getting all of my hobby money lately. John
Totals:
Sub-total: $62.80
Shipping: $5.95
Tax: $0.00
Order Total: $68.75
Another T-6
Hi Hobby
As you can see I have been busy. Here you can get an idea of my progress. Their are serveral more pices to the puzzel left to cut.
For those that asked how I did the cowl here you can see how the rings stack up before sanding.
Got to get back to work and finish this T-6. Unfourtently I completed the wing befor I shot the photo. There are 8 pices that make up the wing not counting the ailerons.
I am going to try to build somthing smaller next time. My new idea is a profile Extra300 that will be powered with the GWS IPS stick motor. Around 24" wing ? Or what ever will hold the equipment weight in the air. John
Time to build another
I flew my T-6 3 flights yesterday. The GWS EPS300C with a 10X8 prop pulls the plane nicely. Yesterday we had around 10mph winds and the plane seemed to take it well.
On my wing I didn't build in any wash out and with heavy elevator or aileron movment I was experiancing tip stall and a mild snap. Still yet it would pull out of that easy enough.
On a fast low downwind pass towards me the little plane got behind me and woops I dorked it in. Compressed the nose and broke the fuse in front of the wing.
With throttle management the 7cell 8.4v 350ma nicad GWS pack last around 5 min and 3min total full throttle. The second T-6 I'm building has some washout built in to tame the snap.
I built the first with rudder thinking I would put gear on it . I will remove the rudder on the next and just use ele,ail controlls. John
AZ
OUCH JOHN
NICE CRASH LOL OH AND YES I STILL WANT THAT PLANE
BUT WORK ON YOURS SO YOU CAN GET THAT UP IN THE AIR
BUT DONT FORGET ME OK THANKS
PM ME YOUR PHONE NUMBER
ILL CALL YA WHEN I SEND OUT THE MONEY AND MOTOR AND GEARBOX
second T-6 coming togeather
Hey Hobby
Can you tell its a T-6 yet ha ha. I am finishing the wing after I post this. This is the straight aileron version it's a little lighter than the first .
But with 220 sq of wing it will carry any pack that you wan't to throw on it. John
AZ
WOW
DAMN GOOD JOB.... :rainfro:
I WILL BE PUTTING A S400 WITH 8CELL NMHI
SOULD GO LIKE A BAT OUT OF HELL
I JUST GOT THE MOTOR BACK 380 WITH 3.1 GEAR BOX
SO WHEN I GET MY MONEY ILL SEND AWAY
I HAVE A QUESTION FOR YA DO I USE TESTOR PAINT? WHERE DO I GET IT AT?
Hi Hobby
I used testors model paint on my Tiger Moth. I have't painted this blue foam yet. But I have a frien at work that has had good luck with Tamiya acrylic paint on the blue foam. It may require a paint propelent pack or airbrush tho. You can get it at the art suply store or a craft store. I have an air brush on order and expect it next week. I'll let you know how the paint works out.
By the way the repair is coming along on the proto type T-6.
Here is a shot of it. You can see the longerons for support. John
AZ
alright
hey when you flew the proto type how well did it fly ? i will be putting a s400 in it lol i hope it screams
i was thinking about getting testors spraypaint at canadian tire
anyways i whated to know if you can get plans for a p51d mustang
or a spitfire?
if so build me one and ill get it too
or a spitfire?
flight chacteristics
The T-6 seemed to have alot of pull with the 370. It had good climb.
If your used to a lite stick this is a differant animal. More of a semi -semetrical wing. Kind of a go where you point it plane.
It wasn't overyly fast but thinking in slow stick it's fast probably 25 to 30 mph just a guess . Is the speed 400 geared ? I havn't seen the zero fly but I would think it would be similar.
The ailerons are very effective. As far as plans I don't have those and am droping down in size to the GWS stick motor for now.
By the way I will put some extra foam in the box so you can test paint on it. Wouldn't want to melt your airplane.
I am wondering if you need more support for the 400 ? Maybe some glass the fuse is just foam . Oh well how much more pull is that over the 370 ? John
AZ
s400 3.1 gearbox
i had that s400 in my skyscooter and well it was flying fast about 35 to 45 mph airspeed looks faster tho
the up weight for the scooter was around 18 to 20 oz
now if i put a s400 in that texan it might weight about 15-17 oz total up weight i think it would go about 45-50 mph
with a 9x7 prop or a 9x8 prop
also ill send ya the sky scooter just the plane if a drop a few bucks if so let me know
thanks
thanks
Twins
Hi Hobby
Thanks for the offer but I don't have much use for the sky scooter. Not my style of plane. I originaly wanted a Zero in trade but we have made other arangments now.
There is a website where you can put in figures such as motor type pack size and prop size and pitch and it will give you the aproxament airspeed .Try this site http://www.csd.net/~cgadd/eflight/calcs.htm
I am finished with your airplane. I have also repaired mine . So first non windy day I will try it again.
Either I'm seeing double or hey your airplane is ready.
Here is a shot. John
AZ
sweet
sweet looks good now just can wait till i get it ill check out that site u posted
oh just a question are ya into car audio? i have 1 pair of 6 1/2 inch kenwood comp speakers 260watts rms clear sound
Set on original offer
Hi Hobby
Your airplane will be here waiting for you when you can complete the transaction. Nice speakers but no thanks. 3 weeks will go by before ya know it. And the weather may even get better. John
