Need help with my GWS DHC-2 Beaver plane
Hi all, i just bought a gws plane. I've never built an airplane before but am willing to give it a go.
The manual for the plane i bought(DHC-2)is vague to me. For instance, i need to drill a hole on both halfs on the fuselage of the plane(for rudder and elevator push rods) but only 1 of the halfs is marked to drill a hole(elevator). Where do i drill the hole for the other half as it is not marked?? Need some advise..................
RE: Need help with my GWS DHC-2 Beaver plane
I guessed where the hole should be and i was right. Remeber you can bend the wire if you mess up just a little, or in the worst case you will have to make another hole and put tpae over the other one. No biggie!
Thanks for the info Scott88. Let me ask you another question. How do you adjust the elevator and rudder section of the tail? Should i buy push rod with adjustable clevis's?
