Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Multiplex Cargo, Brushless?
Old 02-10-2004, 05:11 PM
enrique1123
enrique1123's Avatar
Default Multiplex Cargo, Brushless?
I just finished building my Mutiplex Cargo with the stock 400 motors, but I think it could do much better with Mega brushless motors, has anyone out there run more than 1 brushless motor with a single speed control? It's a cool plane but I think it 'd be awesome with 4 Megas like the 16/15/7's, I got a big enough Lipo pack, 8400 mah 11.1 v, suggestions ?
Old 02-11-2004, 11:05 AM
Jason Beach
Default RE: Multiplex Cargo, Brushless?
I don't believe you can run more than 1 brushless motor on 1 ESC. The ESC has to be able to sense where the motor is in it's rotation in order to know when to apply power to keep it going. I don't think it'll run 2 motors at a time and you run the risk of damaging the ESC.
Old 02-11-2004, 11:49 AM
enrique1123
Thanks for the reply, I guess I'll have to keep it stock then, I am going to have to figure out how to use the cargo door and drop some paratroopers, I've heard it can be done but haven't seen the set up yet.
Old 02-12-2004, 01:57 AM
SRA Foam Flyer
For a cheaper upgrade, you could go with 4 GWS 350's A ratio with 8x4 props. Otherwise, in regards to direct drive, I found mine flies much better with the GWS DD 7x3.5 prop than any other prop I tried. Grass ROG is no problem. In regards to your bombay doors and dropping objects, are they not working for you? I use the 12 bombs from a weapons pack tower sells. As far as 1 controller for 4 motors, I doubt it will work, but several people have very successfully controlled 2 megas of your size with one castle creations controller. Getting to be some bucks though.
Old 02-12-2004, 10:48 AM
enrique1123
I got the cargo door all done and it opens with my gear channel, it looks great but what I was thinking of was dropping paratroopers in a scale like fashion kind of like in formation, the way it works now it would drop them all at once and I did not like that but hey maybe I'm asking too much. I'll try the 7035 prps I thing it might worth a shot, thanks for the info. For what I've heard the brushless is out of the questions. Has anyone seen out there the GWS 747-300 , I saw it in a website but I think that it's not out yet.
Old 02-12-2004, 02:46 PM
Peter Khor
Another option would be to replace the S400's with Long Can 400's (aka S480 for most mfg), swinging a 6x4 prop. From experience with single and twin S400 projects, the is quite a bit of difference. fwiw next plane for me should be a Cargo->B-17 conversion, already got the conversion kit from EAM.
Old 02-12-2004, 02:56 PM
enrique1123
This was my first multi motor plane, I originally wanted the GWS DC-3 but could not find it so I settled for this one, it's great, don't get me wrong but I suffer from the Tim Allen's syndrome "You can never have too much power" Thanks for the replies.
Old 03-03-2004, 03:43 PM
enrique1123
I finally tried the set up with 7035 GWS props and made an improvement, thanks for the idea and it was very inexpensive. Luckily we have a LHS in town that takes stuff on consignment so I'll be dropping off my cargo plane. I want to try my hand at a spacewalker that I just finished and only have to mount the motor and batteries.
Old 03-25-2004, 10:38 PM
peleg66
let me know how you plan on flying you're space walker, i just purchased one and would like to convert to electric, any suggestions would be great
Old 03-26-2004, 10:16 AM
enrique1123
I put on an AXI 2814/12 and I am using 3s2p 2100 TP LiPo, It's an awesome plane and it's great for aerobatic training.
