Budget Slow Stick ESC
MI
Which do you suggest I get? I probably won't be getting Lipos for a while and want to be able to use it in my Zagi too (around 20A continuous). I don't want to spend over $30 and weight isn't an issue. [sm=drowning.gif]
RE: Budget Slow Stick ESC
As far as I know, GWS esc's are very cheap but I think the highest amp you can get from them is a 15A. Wattage has a 30A esc for less than thirty dollars on the [link=http://www.hobbypeople.net]Hobby people [/link] web site but I am not sure about the quality of them. They weigh about an ounce. Maybe someone else can weigh in about this one.
The wires that come out of the GWS motor for the slow stick and their connector will not be compatible with this bigger amp ESC. I am not even sure if you are supposed to put a higher amperage ESC on the little GWS motors but if you do you will have to do some soldering.
MI
Soldering isn't a problem (I prefer a direct connection) - I had my Zagi ESC soldered directly to the 370 SS motor before with no problems (except that Zagi can't build ESCs for cow dung...)
[link]http://www.rc-dymond.com/[/link] Sells a couple of speed controls, one for 30.00$ "a 24 amp" and a 30 amp for just a few more $. These are designed for Lipo's and they have programable voltage cuttoff.
