Perfect LiPO Pack for EPS300CBS ???
Hi All,
I have bought the funny park with EPS300C-BS, Should I use 2 or 3 LiPO cells?
(I have choosen to use the 1500 HD from KOKAM but afraid to use 3 cells=10.8v to 12.6 when fully charged).
TN
RE: Perfect LiPO Pack for EPS300CBS ???
I'd go with 2s. Since you are using B-gearing you are going to running a fairly small prop and you are limited in your ability to prop down - If you use 3s you'll have to use an even smaller one to keep your amp draw below ~7-8A on 11.1v.
Cheers, Phil
Cheers, Phil
