park flyer 1/2 glider?
Oups! Went flying today and my batt. decided to jump out at 300ft. well then the plane piched up and down continuously tell it hit the ground with a soft landing lucky for me!
Spent about 1hr and 10min looking for the batt. never found it[:@] it's nice to know that Mother Nature can land this thing better then I can.
I just thought it was a little funny that this thing flew well with no batt or human control at all and landed perfect. On the down side im out $37 for the cost of the batt..
only if I could have this luck all the time!
RE: park flyer 1/2 glider?
If the battery was mounted close to the center of gravity, ejecting it wouldn't upset the plane's balance that much. You'd still get a good glide out of it, especially now that it's so much lighter!
If your plane will see high G-loads, it's best to have the Velcro going AROUND the battery, like a seatbelt, rather than just between the battery and the plane. Think of this: In a hard turn or a fast loop, you might see 4 G's or more on the plane. Your four-ounce battery now weighs OVER A POUND! Is that little patch of Velcro enough now?
Steve
Steve
I agree completely. That's why I was asking about the type of plane. If it's a Slow Stick or something similar, you can sandwich a piece of velcoe between the battery and the fuse AND wrap velcro around it. If the battery is enclosed in the fuse, you may have to make modifications in order to wrap the velcro around it...or wrap enough foam around it and wedge it in the fuse so it doesn't move around.
The Predator has a simple yet clever way of retaining the battery. There is a large rubber band that attaches to the canopy and then wraps around the nose below it. That way that batt isn't going anywhere
It's a wing dragon and sits in its own compartment. I just need some Velcro or tape...
I found the battery today!!!! It’s a 9 cell Ni-mh 1000 mah (jetset Super) and still works
It’s just that this batt has lots of power I can do some wild tricks that jolts the bat around to cause it to fall out.
Thanks for all the ideas!!
p.s. a year ago I bought some heavy duty Velcro made for concrete and im holding a screen protector(about 4 to 5 lbs) for my big screen TV and it works very nice.
wish i had read this thread 3 days ago....!
ended up doing a similar mod to my freedom flyer
battery flew out while inverted, but still hung on by it's leads - until the prop hit the leads.... left a nice big hole in the grass where it hit the ground...!!
hindsight is a wonderful thing - and i've had tons of inverted fun since i wrapped an elastic band around the fuse/canopy to keep it shut.
