Slow Stick
Slow Stick
Hi all
Well i'v finally recieved my new Slow Stick.....BUT one question i have is that the tail section/elevator (not the fin) is in 2 peices?? is this supposeded to be like this??
Simon
Simon
RE: Slow Stick
ORIGINAL: SimonBryant
Hi all
Simon
Hi all
Simon
I think GWS has found a way to reduce the amount of foam that they use, by cutting the tail sections out of separate pieces of foam. The last 4 or 5 that I've bought have all had the elevator separated from the horizontal stabilizer.
You will have to separate the rudder from the vertical stablizer anyway, so you'll end up with them separated anyway.
Hope all works well for you.
RE: Slow Stick
Hi thanks for your reply, so i need to seperate the rudder/fin assembly, i thought i just need to tape once side and sand 45 degrees accross the hinge line?
Thanks again
Simon
Thanks again
Simon
