gws zero cg
gws zero cg
DOes anyone know where to find the cg on this plane? I read somewhere to balance it on the bamboo spar. If this is the case then my zero is balanced. But, i want to hear other suggestions or opinios. I just finished my zero and plan on the maiden for next saturday, weather permitting of course!
FL
RE: gws zero cg
Balance it on the spar or just behind it with battery installed. Mine is about 3 mm behind the spar and flies great.
What size battery are you using?
RE: gws zero cg
people keep recommending lipolys but i only have a ics 100. I'm going to try a 7.2 600mah. people have said that this batt will work.
FL
RE: gws zero cg
It all depends on which motor you have.
300c will not fly well with a 7.2 volt battery, if at all. I use a 9.6 volt 650 mah with a 9x7 prop. Flies great. ICS100 also.
350c will fly with the 7.2 volt battery but I would use 8.4 at least. 9.6 will draw more amps but it will scream.
Just my 2 cents
Just my 2 cents
RE: gws zero cg
I was thinking of getting a 8.4 v 730mah.. My question is will this fit? Or do i have cut foam away
Well i went ahead and ordered a 8.4 730mah. But, i'm going to try the 7.2 first
