Specs for the Parkzone J-3 Cub prop?
NS, CANADA
I'm wondering if other props can be used with this plane. My local hobby shop has a bunch of other generic type props and none for the Parkzone J-3 cub. Is it possible to use one of these generic props assuming the specs are similar? What are the specs for the Parkzone J-3 Cub prop?
Thanks!
Leafy
Thanks!
Leafy
ND
RE: Specs for the Parkzone J-3 Cub prop?
This is a very good question. I to have had to wait for backorder on a ParkZone J3 cub prop and it is kinda frusterating since my local hooby shop is 50 miles away. I know the shaft size is 3 mm like the Slow V and alot of other slow flyers or park flyers. The length is 8 inches but not quite sure what the pitch is. Right now I am working on using the motor and wing etc off the cub for a arrow shaft project of mine and I am going to try putting the Slow V prop on it first.
Leafy,
I find that the GWS 8x6 props (bright, orange props) work very well on my J-3 Cub. They are lighter, they seem to be better balanced, and they don't cause as much vibration as the stock props.
However, they do break more easily (which is, in reality, a bonus - they will absorb a lot more of the shock from a nose-in than the original props; the number of bent prop shafts, for me at least, has been reduced since I switched). This is offset by the fact that the GWS propellers are a fraction of the price of new, stock propellers.
I believe the stock propeller is an 8x4. The GWS, as I mentioned above, is an 8x6. I believe this means more thrust per rotation with the GWS. I haven't noticed any change in performance, though.
Hope this was helpful.
- Sylvan
- Sylvan
