GWS Tiger Moth
GWS Tiger Moth
Hi,
I fly the GWS Tiger Moth, and I'm thinking of doing it up a bit. Anyone who's done any mods on one of these or a plane like it, or anyone with any ideas, please post them here. Also, one question, what sort of glue would you use on for the wing struts? I used CA glue, but they've come undone.
RE: GWS Tiger Moth
Some of the best mods are using Bamboo skewers 10 inchs long you can buy at any store in the utinsels dept or grill section, The first photo is a really good one, cut out a piece of plastic, see the blue or Black looking line, this is a area that breaks very easy, I cut out a piece the shape of that blue line and epoxey it on both sides as this plane as been broke in two right where the landing gear line go's up,The second is using bamboo poked thru the wings and I use either poylurathane or epoxey , third one shows some bamboo under the tail area poked thru and glued, makes the ele really strong, The fourth one shows where I split bamboo and epoxiy it to the plastic struts that came with the kit, they don't flex very much,
RE: GWS Tiger Moth
If you mean gluing the struts to the wing? If so, use 5 min epoxy. As for mods, due a search on this forum from Tiger Moth 400. There's been other threads related to mods.
Phil
Phil
RE: GWS Tiger Moth
I fly the Moth 400 these are the mods. I have made and it flys great , very scale but with plenty of reserve power:
himax 2025 brushless with a 5.3:1 gearbox and GWS 9X7 prop, Kokam 1500 3s li-po packs, added "flying wires "using 8lb monofiliment fishing line from outer struts braces to landing gear struts, also added a 5th channel as i added a bomb drop to mine as well.
RE: GWS Tiger Moth
I was referring to the pico, but all ideas are very welcome.
Steve, those wing reinforcements look good. The struts turned out very well with that paint on them. I''ve problems with the struts a couple of times, one time it popped right off in a 'rough landing'. Have you noticed any effects on the flying from those mods? Extra weight/drag?
Also, I'm mainly interested in increasing its scale appearance, particularly the langing gear. The landing gear that comes with it looks really bad. I would need one that's easy enough to make, and would need to be light for the Tiger Moth. I'm also thinking of painting the cockpit black, and putting in printouts of the instrument panels. What paint would you recommend? ie safe on foam?
Alex
Alex
RE: GWS Tiger Moth
ORIGINAL: alfat
Alex
Alex
as far as weight go's I believe you loose more haveing the wings flop around, mine weigh about 10 to 10 1/2 ounces, I am going to attach another photo of a stock set of landing gear and one I made with 55 wire for ski's
I will try to put a Hyper Link to one with skis on snow, you might have to cut and paste, no it works, this movie is a TM with skis but the heavier 55 wire and 1 1/2 inchs longer , it will show how much eaiser it is to land with stiffer wire and taller off the ground
[link]http://gwsparts.com/movies/Doc'sTMskis.wmv[/link]
