Slo-v Prop Balancer = Clothes Hanger
Thought you might be interested in a quick and dirty prop balancer. The $5.00 commercial fingertip ones are too large for these propellers.
MySlo-v came with two improperly balanced props. The motor would shake from side to side at about 1/4 throttle. To balance them, I took a thicker metal clothes hanger and straightened the top hook. I then inserted the m3 hex nuts into both sides of the prop. I then put the prop onto the hanger and let it rotate gently until it came to a stop. It was obvious that one blade was heavier. Chop off, add tape, do whatever to get the weight even. Now my motor does not shake any more. I also got some GWS 1180 props. They were balanced out of the package.
My Feedback: (9)
VA
RE: Slo-v Prop Balancer = Clothes Hanger
Ive been useing the top flite power point balancer for my slo-v and its a very tight fit to get the balancer shaft through the prop hole but it goes and that balancer works great.
