NEED OPINIONS!
DE
NEED OPINIONS!
Can anyone out there give me some feedback on this plane?
http://www.redrockethobbies.com/prod...productID=9470
I'm trying to decide between this and the Parkzone Stryker, which everyone says is great.
I want to get something a bit more exciting than my Challenger.
OR
RE: NEED OPINIONS!
Why dont you try a plane that is upgradable.... or that you can use the parts for another plane? I dont like buying "all in one" packages because if you want to upgrade them at all you have to replace ALL the electronics.
Why dont you try a GWS fromosa, Im sure you will like it all around. And then if you want to use the motor, servos, reciever, speed control in another plane you can. But you have to buy all these electronics seprate from the plane.... well it comes with the motor and gearbox.
It may cost more money now.... but it will save you some in the future.
DE
RE: NEED OPINIONS!
Thanks for the advice but, much as I admire some of the scale planes available in kits, I don't have the time or space to build anything. Hope to later. For now, I bought the Stryker.
ME
RE: NEED OPINIONS!
the stryker is a fun plane to fly no doubt.. just be advised, the electronics are prioritary and servos gears are weak. avoid control surface impacts.. even minor ones.
you'll have blast with it.. there are a bunch of stryker threads with good info here, you'll want to read them..
flybypdx, has good advice in that post..
