Super stick like SS?
OR
I now am using an AXI 2808/20 on my slow stick because it weighs close to 30OZ with my AP gear. Its not bending the fuse and breaking the wings because of the Gs when I am fun flying.
Is there any kind of an airplane that uses the same stick concept that is more durable for my slightly acro moves?
WA
RE: Super stick like SS?
i dont know what airplane would be the best for that motor, but i live about an hour upriver from you, in white salmon, right across from hood river
CA
the parkzone slow V has a carbon fiber stick for a body instead of an aluminum one. I was at the hobby shop earlier, and saw they had the body, and all wing and tail mounting pieces, for $10. youd just have to glue on the sticks tail, shim the front for the GWS gearbox, and swap the parts. That should be stiff enough, and still really light
CA
ORIGINAL: FlybyPDX
3/8" x 3/8" balsa stick in the fuse helps some also.
SG
