Parkzone Typhoon 3D RTF
BC, CANADA
Not sure if this has been discussed already: Parkzone's new 3D park flyer is on the way...here's some details...well...LOTS of details:
Exciting things are happening once again with ParkZone. As you know, we have recently launched the P-51D Mustang, and we are now bringing to you yet another dimension to the family lineup – the Typhoon 3D. This plane is for experienced RC pilots who want all the thrills of an unlimited 3D electric park flyer without the hassles of having to build one. Equipped with oversized control surfaces and a powerful ParkZone BL400-15T brushless motor means it can perform the most aggressive 3D maneuvers imaginable with laser precision and power to spare. Hovers, harriers, torque-rolls, waterfalls—the Typhoon 3D does them all. And because the wings and fuselage are molded from ParkZone’s super-strong, feather-light Z-Foam™ material, it can handle the punishment of these high-energy 3D aerobatics without getting bent out of shape. It’s tougher than EPP foam and can easily be repaired with CA.
Getting the Typhoon 3D flying is about as simple as it gets. Everything you need is in this box. Just attach the wing and tail, charge up the included battery pack, and in as little as 40 minutes, you’re flying. Once in the air, you can choose between “low” or “high” elevator and aileron rates with a flip of the transmitter switch.
Experienced model builders will also appreciate the Typhoon 3D’s removable receiver/ESC module and servos that can be used in other brushless 400 powered park flyers. That includes V-tail and delta wing applications thanks to selectable control mixing in the receiver. You can also adjust the ESC’s auto-cutoff to work with 3-cell Li-Po battery packs.
This plane is ground breaking because of the combination of features that it boasts – a brushless motor, 3D flight, a 4-channel radio, and ready-to-fly design – not to mention its incredible price of $219.99 at Horizonhobby.com or at your local hobby store.
We believe that the ParkZone Typhoon 3D will be a huge hit with experienced radio-control pilots, whether they are current ParkZone fans who are ready for the next level of performance or 3D RC pilots with a lifetime of experience who are looking for easy 3D park flying fun. No other plane on the market offers this much 3D fun in one box, with everything you need to get flying
Features:
Four proportional channels that allow users to have full control of 3D flight
A gear-reduced ParkZone BL400-15T in-runner brushless motor that provides long, efficient run times and gives power to spare at varied speeds
Li-Po compatible technology that allows users to upgrade to a 2100mAh 3s Li-Po battery from the included 9-cell 1000mAh Ni-MH battery pack for more power and longer flight times
Z-Foam - a revolutionary hybrid foam material that is stronger and lighter than most foams
Symmetrical airfoil for advanced aerobatics, such as hovers, harriers, torque rolls, and waterfalls with the standard Ni-MH battery
Reusable 72MHz FM radio system that includes industry-standard 3-wire brushless ESC and servos with separate receiver
Dual elevator and aileron rates thanks to the Mode Change Flight Control system
Mode Change Flight ControlTM system that allows pilots to select from the transmitter the mode that's most comfortable for them
Dual aileron servos
Two propellers - one for speed and one for power
Steerable tail wheel
8 AA batteries for the transmitter
Fully proportional 4-channel FM transmitter in six frequencies
Rechargeable 9-cell 10.8V 1000mAh Ni-MH battery pack
1.8A variable rate DC peak detect charger that charges 5- to 10-cell Ni-MH and Ni-Cd batteries
Specs:
Wing Span: 39.5" (1000mm)
Overall Length: 34" (862mm)
Flying Weight: 26 oz. (740g)
Motor Size: ParkZone BL400-15T brushless with gearbox
Radio: 4-Channel FM on 72MHz
Servos: Four 3-wire servos
Trim Scheme Colors: White fuse and wing with silver, black, and red decals
Prop Size: 14x7 and 12x8.75
Speed Control: ParkZone brushless 20 Amp
Recommended Battery: 9-cell 10.8V 1000mAh Ni-MH (stock)
Aileron: Proportional
Elevator: Proportional
Rudder: Proportional
Throttle: Proportional
Approx. Flying Duration: 8-10 minutes
Approx. Assembly Time: 15 minutes
Gear Ratio: 8:1
Available Frequencies: Channels 17 (72.130), 19 (72.170), 21 (72.210), 50 (72.790), 52 (72.830), and 54 (72.870)
X-Port: No
Charger: 5- to 10-cell variable rate DC peak charger for Ni-MH and Ni-Cd batteries
Landing Gear: Foam wheels
Steering: Proportional
Features:
Dual aileron servos
Specs:
Gear Ratio: 8:1
X-Port: No
IL
RE: Parkzone Typhoon 3D RTF
Nope, it's in the little magazine horizon hobby sends out in e-mail and print form. Looks really cool.
Alex
Edit: also check out http://www.parkzone.com
Alex
ND
At 270.00 msrp the price is kinda steep.
It does excite me though.
I have to ask a question of ParkZone though.
The servos. Is it possible to substitute maybe a Hitec or GWS servo if the need should arise Ie quick infield repairs?
Is there a possibility that ParkZone may use this system inthe P51 Mustang rather then the beginner electronics it is listed to have?
The receiver channels??? Is the crystal able to be changed on the receiver so that someone can use their current radio if they feel the need????
AK
Rat1
I have been flying the Slo-V since last fall and have a Stryker ready to fly once the snow is gone (Just bought parts and am using the Slo-V TX. I have had my share of burned up motors, broken fuses, back ordered parts etc..... but in general I think that I would have had just as much trouble with a slow stick and full TX RX setup. I keep considering buying a regular radio setup etc. but I can never seem to price anything out that even comes close to a ParkZone setup. Even at rock bottom prices I can't imagine getting a brushless, 3-D plane with flight pack and battery for much less than $219.99 (on the Horizon Hobby Web site). Only thing I would like to change about this latest offering would be that the plane could have been the Tensor 4-D since it sounds like it might be a little more flyable for a novice pilot. But quickly looking over the specs. you should be able to transfer the electronics from this kit to something like the Tensor for about $50.
Great job to the folks at ParkZone. Keep those prices down. You have a loyal customer here. Maybe for your next offering you could put out a real tiny indoor flier for those cold, dark winter nights when the grade school gym is the only place to fly.
Good flying.
Good flying.
AZ
Yes, I am seriously thinking of buying this plane. It appears that the electronics are transferable to one of the already existing ARF 3d flyers. Not only that but I'm hoping that they really do mean that it can already do 3d with stock setup.
If what they are saying is true, then Parkzone is right on the ball, they have it totally!
AZ
Yay, I'm on my LHS's list to call once they get the Typhhon in. They have the price at $220. Wish I had some actual information on what the stock performance is. All I'm going on right now is the features list and an interview from the Toledo expo.
The plane looks very cool and the price is very good for the set-up, in my opinion as it will probably sell for about $225 in the hobby store. I think ParkZone has created a great package.
One big concern:
Many of the people who buy this package will be first or second plane flyes who are not members of RC clubs.
Up till now HobbyZone and ParkZone have been on 27 mhz. This package is on 72 mhz. I strongly urge you to take this plane to a club field to fly. You are now flying on the dedicated hobby radio channel that the traditional RC flyers use.
If you are flying within a mile of an RC field, a field you might not even know about, one of two things can happen.
While you are in the air, one of the guys at the field turns on his radio on your channel - You crash!
Now, that is not a good thing and someone could get hurt, but let's face it, your plane weighs 10 ounces and is traveling fairly slowly. Now look at it the other way.
Some guy is flying his 1/4 scale pattern plane. He has a big gas or glow motor on that plane with over 1 HP. The plane weighs 18 pouns and is moving at 75 MPH. Your turn on your radio on his channel. He loses control of the plane, flies it into a crowd of people and kills someone.
Forget the issue of liability and such, you are now playing in the same space as people who have spent years developing the procedures to avoid frequency conflict. This plane, and others like it on the 72 mhz radio band can cause some real problems.
On 27 mhz, this can happen also, but chances are you are going to interfere with another parkflyer, a car or a boat. now you have the potential to bring down a 50 pound jet traveling at 200 mph! If it crashes on the field, well that's too bad. His $20,000 investment is gone. However it it doesn't crash on the field it could hit something else and cause a lot of damage.
This is serious stuff and I am afraid that very few customers will have any idea of the damage and the danger they represent.
Give it some thought. Find the local RC clubs. If you are going to fly on 72 MHz, be responsible. Don't put people's lives and property at risk.
One big concern:
VA
Man Parkzone can't win can they. People complain about the fact that they use "Toy" electronics and then when they finally come out with a plane that uses "real" electronics people complain about that.
ORIGINAL: L0stS0ul
I think ParkZone makes a great product and does a really good job packaging it. My concern is with the knowledge and experience of the customer. Ignorance of proper procedures can cause problems for everyone. I urge careful use of the radio.
You are into the hobby band now. With that power comes responsibility.
AZ
I guess thats why people like to buy ARFs. They buy the electronics and motors themselves so they don't have to complain about what it comes with.
I agree that having a RTF parkflyer plane on 72 may be dangerous if some precautions aren't taken by the owner. But it seems if a person just takes the right precautions they, and others, should be fine. I mean, if you don't have enough money to be with a club, you have a good chance you can still fly, because fields aren't quite everywhere. I know that this site, and the AMA website, include field locaters. It isn't very hard to find out if you are close to a field.
This web link takes you to a club locater site.
It is important to note that the address provided is NOT the field, but a contact in the club. The field could be 20 miles away from the address.
Find the clubs, contact the ones in your area and see where their field is located. Visit it. You might find that you would like to join, but even if you don't, you will know where they are flying so you can try to avoid conflict.
http://www.modelaircraft.org/clubmai...5E31DE4FA6F552
Clear skies and safe flying!
VA
Look at some of Rat1's parkzone posts, he seems to have a hatred for the 27mhz electronics and has called on parkzone to release the P51 with "real" electronics. I've also seen many other people complain about that in various other forum topics. I believe it's even caused a Parkzone employee to respond to the electronics questions.
I personally have no problem with parkzone or hobbyzone electronics. They have worked great for me. I've had 2 hobbyzone planes and I am currently flying the cub with no electronic issues. I can't wait for the p51 and when I'm good enough with that I'll upgrade to this plane.
I agree that people need to be careful but I doubt it will be much of an issue. You run the same risk every time you go to the field that someone (even pro's) mistakingly turn on their controller that just happens to be on the same frequency while you just happen to be low enough to the ground where the hit just happens to cause your plane to plummet to the ground. Personally I try to fly high enough that if a hit should happen that I have enough time to try and recover. I also try not to fly my planes near buildings or people. I really could care less if it hits a tree or a goal post.
TN
I can't wait for this thing to come out. I've been looking at building my own 3d foamy, but I couldn't come anywhere near that price even w/o the Rx. Maybe I don't know where to look. As far as the 72 MHz issue is concerned, I noticed this on Parkzone's website:
Reusable 72MHz FM radio system that includes industry-standard 3-wire brushless ESC and servos with separate receiver. Availble on six frequencies.
If everyone flying larger scale planes at their club switched off these 6 frequencies, there shouldn't be much of a problem. I doubt the average user would switch out his crystals for a new frequency, and in turn those that do will probably understand the risks of doing so and will hopefully take the necessary precautions.
BTW, I wonder what kind of Tx the Typhoon will be included and if there is any chance of it having exponential rates. I may end up going the ARF route if it is junk, because I'd like to get a nice Tx that I can grow with, as I'm really interested in getting a Heli soon as well and I already have two receivers to carry around to fly my Slow Stick and stock Stryker. I also don't know if I have the patience to wait until mid July :P.
BC, CANADA
The Toledo Tradeshow coverage videos are up on RCU now...there's one covering the Parkzone booth...you can see the stock transmitter that comes with the Typhoon:
Here's a direct link:
http://www.rcuniverse.com/magazine/a...article_id=508
Look for the one titled "Horizon/ParkZone Booth Tour"
WI
I called my LHS today. The first one he gets is MINE.
I don't know how well it will fly, or 3D, or any of that.
Fact is, I don't care.
I've been wanting something to get my rear up in the air and this is it. The fact that it will take about 1 minute to be ready for flight(add battery charging time) is the icing on the cake. I am just too damn lazy to build at this point.
And the price is good.
Hi,
A few thoughts on 72 mhz (you are correct, we cannot win, but we are pleased with our product performance in any case).
The government, and AMA, etc. have chosen not to make any regulations (or reccomendation) on parkflyers, RTF's and so forth...
I don't really like a lot of park flyers all over the 72 band myself (I fly turbine jets for my hobby.)
In this scenario, E-Flite and ParkZone have tried to make our OWN compromise that we will do our best to stick to (it may not always be possible).
We have chosen SIX channels on the 72 band that we will offer lower cost (likely to be more backyard or park friendly) RTF aircraft on.
I am sure you want to know what they are... and they are in the spare parts on our web page for the Typhoon and the Blade CP heli.
CH. 17, 19, 21, 50, 52, 54
While I am (very) sure this will not make everyone happy, I hope most will recognize that we are trying to act as responsibly as the conditions allow! (I wish other people with similar products would make an effort to join us.)
Best Regards,
David
http://www.horizonhobby.com/Shop/ByC...g&SubCategory=
Best Regards,
David
ORIGINAL: dribbe
Best Regards,
David
Best Regards,
David
With 6 on the 27 mhz band and 6 in the 72 mhz band, there are now 12 out that for the RTF mass market.
I agree, that you have made commendable effort to bring the 72 mhz band to the RTF market and offer some frequency control at the same time.
Thanks for letting us know that this was not just random. I for one appreciate it.
Can you say whether these sets are the full 750 mw that the typical full power sets are or if they are possibly a bit lower in power. That would also contribute to avoiding frequency conflict. I believe, for example, that GWS's radios are around 300 MW which is way more than enough for a 1/2 mile range. More than enough for parkflyers.
NC
I belive if anyone were to fly turbines, I would think it smart to use a pcm radio or whatever the radio was i saw that AUTO CHANGES CHANNELS TO EVADE INTERFERENCE , just my $.02
Hi,
Thanks for the support AEAJR. We try to put some thougth into it. I do not know the actual output power at this moment.... I expect it is between 500 and 700 mW. I do know it passed the FCC regs.
AMD, I don't think any hopping radios exist on the hobby market for air right now. PCM can help, but all existing systems are able to be shot down.
David
David
The one thing that I read about the Typhoon that is disapointing is that you get the kit with their radio. Most of us that run on 72MHz have and prefer our own radio. Wouldn't it be great to get a Typhoon that you just drop in a X-Tal for your frequency and the Radio (if you need it) is optional. It would reduce the price as well.
ORIGINAL: billz
