Super Decathlon rudder goes wrong way
MN
RE: Super Decathlon rudder goes wrong way
If you have servo reversing on your radio just find the rudder channel and reverse the switch.If no servo reversing you need to move your servo arm to the opposite side on the rudder servo. Good luck, Rick
David,
The connectors on my servos are molded in such a way that unless I were to apply extreme force, they would not plug in if I reversed them.
Stupid stock Park Zone radio doesn't have servo reversing YET I found a way to fix it and my stock radio will have servo reversing when I get back from the hardware store.
As I recall... you can trim a little plastic, and this will allow them to be flipped....
David
David
ORIGINAL: mwrey
David,
David,
