Larger wing for Firebird Scout
FL
Hi,
I would like to know if it's possible to add a larger wing to the Firebird Scout, f.e. the wing of the Commander. Any help appreciated.
JC
JC
RE: Larger wing for Firebird Scout
the wing of the commander i think is wider than the wing of the scout. it might not fit. also you would add more weight that way which the plane might not be able to pull. i dont know much about the scout though cause i dont have one but i do have a firebird 400 with a commander wing as they are the same size. but i do remember seeing a scout set up at a local hobby shop and im pretty sure it was smaller. im not sure what the point of a larger wing is either. but if you relly want a larger wing i suggest getting balsa and making the wing bigger the way you want that way. but before you do anything permanant you should tape the balsa on using duct tape and see how well it acctually works
IN
Im sorry its the firebird2 or the st.
http://www.hobby-warehouse.com/firiiyelstan.html
