Where can I find a stronger GWS gearbox?
RE: Where can I find a stronger GWS gearbox?
How is the motor secured with that? Does it screw shut and clamp onto it?
I see they also have what looks like a more direct GWS replacement thats almost identical to the GWS gearbox. The thing is though, I want to use APC props.
I want to use this for a Magpie thats built around the GWS 350C-C motor.
Some clamp on, some screw on - the brushless motor I use screws into the gear box. I run apc props - the mount comes with both shafts.
Oh, ok. I saw that the GWS shaft was optional, I thought it was something you had to buy extra. I see that one is for a 20mm and the other is for a 24mm. Which one will fit the GWS 350C?
