Lazer 3D motor
My Feedback: (47)
Lazer 3D motor
I currently have the stock set up for my Lazer3D, and was thinking of getting the new Astroflight 010 brushless motor for it. Does anyone know about this setup? I've read the hacker motor is the way to go, but the Astroflight is less expensive and easily purchased. Should I go geared or direct?
Lazer 3D motor
I'd go with the Hacker. One of my buddies has the Hacker setup and he has nearly unlimited vertical. The Astro although it will power it with authority won't give you the performance you're wanting if you're putting a BL motor in.
I believe the Hacker of choice is the B20 15L
--Paul
--Paul
Lazer 3D motor
What did you finally do with your Lazer? I didn't want to spend the money on a brushless so I put a BB 280 brush motor and a BB gearbox. It improved flight, although, won't 3D. It'll do nice loops and rolls.
Lazer 3D motor
I haven't personally flown the ML3D so I can't be comepletly sure, but I think the 3D part of the equation is merely a label, that doesn't quite apply to it. (Some 3D, but not a whole lot)
This is from what I've heard from others, and watching my buddy fly his Hacker powered version. There are so many "3D" kits out there that couldn't 3D to save your life.
--Paul
--Paul
