Aerobird Xtreme dives on launch
I am having a good time flying my ABX and most of the time it's great. Lately It seems that after I get that first flight in bring it back down then relaunch it, it wants to nose dive into the ground. Everything looks good and where it should be. Could the battery be too weak for a second launch? I also found a nice trick to keep the main wing from moving around, just put a couple lengths of double sided scotch tape on the body where the wing mounts. It gives it just enough grip so it won't slide around under those rubber bands. Thanks
RE: Aerobird Xtreme dives on launch
I suspect that you are correct about the battery. As you will know it needs some effort to get it into the air the first time so it's going to be harder the second time.
