Hi have just heard a click from my servo!
On one of my sl o s i was adusting the tail and the servo "snapped" e.g i herd a spapping sound. Can I fix it? or does it need to be a new servo?
GA
RE: Hi have just heard a click from my servo!
depends on the servo... if you were forcing the servo, you may have killed the gears... if it is a good servo, gears can be replaced.. if it is a cheapo, then pitch it....
You can open up the servo to verify if the gears are broken.....
FL
ORIGINAL: slo v rule
Thanks, i opened up the servo and the gears had just got displaved chers
If they are the stock servos, you can buy rebuild kits from Horizon, for the gears.
