Eflite P-47
#51
CA
RE: Eflite P-47
ORIGINAL: odiemac
I maidened my P-47 today, and found it to be predictable, even at low speeds. However, my elevator trim was off, and flying with back pressure on the stick was pretty nerve racking.
#52
TX
RE: Eflite P-47
I don't believe it !
Look what the cat draged in on a sunday afternoon. Fed-ex ground on sunday? It is unheared of, butI like it
Placed the order on wednesday afternoon got the plane on sunday , not bad.
#53
RE: Eflite P-47
I have 2 of these on the way. I was thinking of putting retracts on. Has anyone done this? Pics or instructions?
Also, I am going to run the Rimfire 35-30-950 kv motor on this. Should be plenty of power, about equal or a little more power than the smaller Park 480, and I was thinking about an APC 11x7E prop. Any ideas?
#54
RE: Eflite P-47
Hi,
Yes there's a possibility for retracts. Look at the RC Group Thread on this electric warbird at [link]http://www.rcgroups.com/forums/showpost.php?p=5694610&postcount=93[/link].
I've also posted a few improvements on this great product. But putting retracts on this bird is just a little bit toooo much for me.
#55
UT
RE: Eflite P-47
i noticed while i was building mine that the stock motor, when i place it on the mounting stick, is off center with the plane.
does any one elese have that on theirs?
#56
TX
RE: Eflite P-47
Yes it is normal.
This how the motor's and the prop's torque pull is offset. Usually aimed to the right and down a bit.
If the stick would be straight forward, the plane would climb up and pull to the left so you would have to compensate all the time.
#57
IL
RE: Eflite P-47
I'm planning on flying mine, stock 4 channel for a while....before upgrading it to brushless....I gotta find something to do with all these brushed motors I'm accumulating....Pat
#58
RE: Eflite P-47
Hey guys;
I am a total electric novice...been flying gliders and power planes fro almost 20 years but this electric stuff is all new to me and I need some advice from you !
I just bought one of these as well... my power setup is as follows:
Park 450 Brushless Outrunner
Phoenix-35 Brushless Controller
Thunder Power 2100 Mah 3 Cell LIPO
Servos are: E-Flight S75
Prop: APC 11 x 7E
Sounds like the only place I went wrong here is on the prop based on what I read in this thread...
I was wondering about paint... any recommendations on paint that will not eat up the foam ????
Prop: APC 11 x 7E
#59
TX
RE: Eflite P-47
ORIGINAL: patnchris
Cub_boy,
I used Krylon -brand spray paint on my foam supercub. It's a really good paint, it dries in 10-15 min, adheres great and have good coverage.
Walmart has it.
#61
UT
RE: Eflite P-47
has anyone had any bad experiance with the e-flite S75's servos? Im thinking of useing them on my P-47. there are lots of reviews that say they stripp out fast, any comment on that?
#62
IL
RE: Eflite P-47
I think one reason that we're seeing a lot of E-Flight s-75 failures is that there are a lot of them out there. It appears to be the servo of choice for the majority of medium sized parkflyers. These planes are also the choice of many novice or first time pilots. So because there are lot of them, and they have a tendency to be crashed more, the failure occurence is bound to be higher.....Pat
#65
RE: Eflite P-47
Remember to remove those bombs until you've mastered the landings...
Wonder how the little rascal would look with skis?
Oh and also, be careful in the cold weather, if you're using a JR receiver the company doesn't ''guarantee performance''...
#66
RE: Eflite P-47
ORIGINAL: patnchris
friendly" esc's to match!
Thats why the option of using the stock motor first in my new p47 wasnt viable. I wouldnt have had any batteries suitable to power it. Shame!
Rod
#67
TX
RE: Eflite P-47
Rod,
I hear you... I am in the same shoes. You have a couple options:
(This is what I do)
grab a kitchen timer, one with a buzzer or a bell, or you can use a stop watch too( my casio watch has a count back timer)
set it to 10 minutes at first. Fly your P-47 with the lipo. land when the buzzer go off. In 10 min it will surely not deplete a 2200Mah battery. when you go home check how much charge the lipo takes. Hopefully you hare a charger that shows how much juice was put in the battery during charging) record it.
next time set your clock to 15 min. and do the same see how much is depleted form your lipo.
i usually fly 15-18 min on a 2200 lipo. and still has reserve.
option 2: get your self a "li-saver" this is a device that hook in line between your ESC and the receiver (throttle wires) and one lead hook on to the battery when it sees the bat voltage gets to 9.0V it will cycle your throttle on-off a coulple times.
there are other devices available, one that will flash a bright LED- mounted on the plane somewhere- when your battery gets to a low voltage
option 3 : in my p-47 I have a 20 amp brushed ESC (not li-po friendly) often I just use a standard 10 cell 2/3A battery pack . I get a good flight out of it.
option 4: li-po friendly ESC. just like the typhoon has where you can easily set your batt preference- li-po or ni-hi and it will do the cut of for you.
(This is what I do)
#68
RE: Eflite P-47
Thanks for all that mate,
I will check out my Swallow charger .. I think from memory all it tells me is the charge duration .. not sure. What does yours tell you that would indicate the level of depletion ??
I also have a 2s lipo I would like to run in my Freedom and supercub .. if I could use the same method to determine flight time it would be really cool .. the inline li-saver sounds like a good option too.
Cheers
Rod
Cheers
Rod
#69
NJ
RE: Eflite P-47
hey guys, got this plane. build was very simple and i just love the looks. any idea for a prop i have a 450 outrunner with a 20 amp speed control also when i did the rudder it came out all weird will post pictures soon
#72
TX
RE: Eflite P-47
ORIGINAL: Rowdy_b64
Rod
Rod
In theory, what ever is drawn out, the same amount can be put back in. Say: in a 15 min flight I may draw 1600Ma out of the 2100Mah li-po pack. I know this because when I go to charge it, (once the battery is peaked or fully charged) the charger's display indicates that about 1600 Ma was charged back into the battery.
Now this is only true if your charger is a peak charger and stops charging once the pack reach full holding capacity.
The same is true for other batteries such as nickel metal hydrates.
My ten cell Nm-hi pack is rated at 1100 Mah.
Just about every time I run the battery(Nm-Hi) fully down ( the airplane accelerates poorly, or just barely flies) when i go to charge it the charger peak charges the battery and displays 1000- 1150 Ma.
#73
TX
RE: Eflite P-47
ORIGINAL: kyle t
looking off of those pics i cant see anything in particular that looks wrong with it, on mine i just decided not to use the rudder. (less complex)!
Or fly upside down, keep level flight and steer only with the rudder.
Barrel rolls -.... you need rudder.
#74
TX
RE: Eflite P-47
ORIGINAL: thenamshow
#75
RE: Eflite P-47
ORIGINAL: kyle t
Just wondering, how would the absence of a rudder effect aerobatics down the track. Not that I do this, but I believe I have read that some things require rudder .. like a hammerhead stall .. (or rather recovering from it! )..??
I know that I dont need it for normal flight .. so I havent bothered with it an the min.
Cheers
Rod
