JR ES306 servos
CA
JR ES306 servos
My son found these in Australia. I plugged them into my JR R610M Rx and they worked fine.
Description (It is in Japanese)
Size: 19.5 X 11.5 X 21mm
Torque: .05kg / cm
Speed: 1Sec/60 deg
Weight: 6g
The picture shows them next to my Cirrus RX and CS-10 servos.
If I got the calculations correct, they are a bit heavier and a slight bit weaker than the Cirrus CS-10s.
The JR (6ch) Rx and two servos weigh 6g more than the Cirrus (4ch Rx) with two CS-10s.
Torque: .05kg / cm
Speed: 1Sec/60 deg
Weight: 6g
