Ace Littlest Stick
CA
Ace Littlest Stick
Here's one for you...
While cleaning the garage I found my old (fuel soaked) Ace Littlest Stick. I have a NIB 280 and I have been looking for a plane to stick it in. Seeing the stick gave me an idea and I think you can guess what it is.
As the ALS only weighs 70g I think I could bring it in at 7oz RTF. Trouble is, it only has 81sqin of wing area. That gives it a wing loading of 12.5 oz!
What do you think, will it fly?
Ace Littlest Stick
I have not heard the name LITTLEST STIK in many, many moons. I too have one sitting on the shelf. Mine has trike gear with 1/2 inch wheels. 0.020 Cox engine still mounted. If memory serves it had a weight of 7.0 to 7.75 onces and would glide for a long time.
Dru.
Dru.
CA
Ace Littlest Stick
Dru.
That's the one. I dug around and found the plans... Three 8 1/2 X 11 sheets!
I'll clean it up and take a picture tomorrow so I can post it.
I don't remember the glide, as at the time I didn't have real small radio gear. It was a bit heavy RTF, but I do remember taking it off of a picnic table so it couldn?t have been all that overweight.
Ace Littlest Stick
I had two of the very pricey Airtronics micro lites, standard Rx with the case removed, small 270mah nicd battery. I do remember that it was a total handful. If you took your eyes off of it, it was gone or in the dirt.
It did make you a better pilot. You did well if it lasted ten flights.
Dru.
Dru.
Ace Littlest Stick
Hi rahtware,
I have fond memories of flying my littlest stick with the Cox .020 with 1980's vintage micro flight pack. I also still have it and have toyed with the idea of converting it to electric. I saw a similar-looking stik model in a recent Micro Flight mag, but I forget the dimensions of that plane.
As to 12.5 oz/sq ft wing loading, that doesn't sound very high, but it will probably need some speed to fly "right"...try electrifying it and tell us all about it! Good luck!
CA
Ace Littlest Stick
I was getting ready to start on another plane, but this looked like it would be so easy............
Oh well, here goes.
LS empty = 73g
Old gear including: Cox .020 w/prop, Futaba 4ch "micro" Rx, 2 X unknown brand of "micro" servos, 250mah flight battery. Total 149g
New gear including: GWS 280 DD motor w/prop, 2 X CS-10 servos, Mrx-4 Rx, C-10 ESC. Total 133g.
Missing: Fuse upgrades and flight battery.
Here is a picture of the LS and it's old and new radio gear.
Oh well, here goes.
LS empty = 73g
Littlest Stick
I still have mine, previouslyTee Dee .020 powered with Ace Pulse Commander Single Channel. The GWS EPS 100C (280) 2.8:1 and an 8 cell 300mah NiMh pack and 8X6 GWS prop with submicro R/C stuff should work. An GWS IPS with 8X6 prop or Direct Drive motor/prop should also work. Plane will fly fairly fast. Might want to add a coupla bays to the wing and beef up the dihedral break areas a little.
Ace Littlest Stick
Ok so you got me all interested and now I have to try what you did. All I need is a prop adapter and small props for the 280 and I'm in! Soon I'll get a digital camera and I'll send in my pic.
I see you ised those little black wooden wheels that came with the kit! I didn't use 'em but might make a whisker landing skid to keep the prop from hitting on landing.
Good job on the makeover, I hope it flies great!
