parkzone cub adding ailerons
FL
RE: parkzone cub adding ailerons
Yep, if you do a little digging in the Cub forum there is step by step instructions and photos of it. Or if you have switched out the electronics for standard equipment you can go all out.
Mine had ailerons, rudder, elevator, and tail wheel steering.
Very easy to do.
Very easy to do.
GA
eka1 it is a thread here in this forum, there are 2 one for the PZ cub and one called Shun Da Cub, both are good threads and can offer you all the help you need for the mod, I added the ailerons and steerable tailwheel to my SD Cub and it was easy and made it a whole new plane, A few things have to be done for it to work right but it's all fairly easy. Good luck with it
