AIR HOGS AERO ACE - new JET Vs old BIPE
PA
Guys!
I bought the new AIR HOGS AERO ACE - JET . I couldnt get the old Aero ace biplane in toys r us. Has anyone flown the jet? What happened to the bipe version? Any comparisons which is better? Pls let me know.
747.
747.
RE: AIR HOGS AERO ACE - new JET Vs old BIPE
The jet is a little faster and handles wind a little better, but requires a little more room for making turns. Basically, if you will be flying mostly outdoors, get the jet. If you will be flying mostly indoors, get the bi-plane. Both benefit from a dime taped to the nose to reduce the porpoising tendency. If you plan on adding a screw for a more permanent weight, make sure that you don't screw it into the battery. (Sure takes the fun out of it when the battery starts to smoke and the fluid goes all over the plane.)
