GP "Spirit of St.Louis"
My Feedback: (195)
GA
I built and attempted to fly a Great Planes foamie "Spirit of St.Louis". The plane went together very easily and I was very reserved in my use of epoxy. I even used foam friendly CA in place of epoxy where I could to save weight. The plane balanced out with no additional weight! It uses a standard 280 class motor running on a 4.1.1 gear reduction. I used the recommended battery, a 350mah 9.6 volt and it was fully charged.
The plane was started and gingerly tossed into a 3-4 mph wind. It failed to gain altitude and was very sluggish. I attempted to fly it several times with the same result each time. I have built several ARF's and stick built planes so I do not believe my building skills are at question, Is it possible that this plane is underpowered? Or is it just an electric dog?
LOOPMAN
LOOPMAN
GA
There is a product review in the "Winter 2003" issue of Backyard Flyer.
Said best flown on a day of light winds 2-3 mph to overcome the drag of the struts. 3-4 mph may be reasonable, "what a difference a mph makes" (a little play on words).
They also said if you want to increase performance you can put in a 380 motor which will fit without modification and check the balance of the plane. I don't consider the plane anything other than one to just fly around without fancy tricks. Not a high performance plane.
Since they mention the drag of the struts you man want to consider removing the struts or replacing them with something with less surface area. I don't know what the struts add to landing gear strength.
There is another suggestion to installing the prop so it can be removed easily that you might want to take a look at, so if you can find an issue of Backyard Flyer you might want to check it out.
CA
Loopman
Could you post the weight and wing area. It would be interesting to me, to see the lower limits of what a geared 280 can pull.
My Feedback: (195)
GA
Spirit Specs
Rahtware,
Here are the specs taken off of the Tower website.
SPECS: Wingspan: 40.1" (1020mm)
Wing Area: 253 sq in (16.3dm2)
Weight: 12.4 oz (350g)
Wing Loading: 7.1 oz/sq ft (21.7dm2)
Length: 25.5" (650mm)
Control Throws-
Elevator: 5/8" (15.9) up and down
Rudder: 1-1/4" (31.8) left and right
Electronic Speed Control: Follow mfg's instructions to arm/set range.
Center of Gravity: 1.61" (41mm) back from the leading edge of the
wing on both sides of the fuselage in an upright position.
Control Throws-
