Help!!! Servo Choice for GWS Beaver or Moth
SK,
I have a JR XF631 Radio with the 537 Ball bearing servos and a R700 7 channel reciever, and was wondering if the beaver or moth could handle this set up.
I have one Pico flight pack on order, and was wondering if I needed to order another, or if I could use the radio's stock equipment.
I also have an extra 2 amp GWS ESC to use with the stock equipment if possible.
I want to build noth kits, but not sure if I should just bite the bullet and get to pico sets or not.
Please respond ASAP.
IL
I have two Moths and I would go with the pico. you want to save wieght for a bigger batt. The batt that comes with the pico set is junk. Get a 500 Mah NiMh, this will require you to make the batt slot bigger, but will give you much better air time. Loop and loop. also use 5 min Epoxy instead of the tape that comes with it. this will make for a much tougher plane that can handle....some wind. I said some....
