sr batteries x250
sr batteries x250
I have this plane built stock and its a dog. Any suggestions on change in motor to get more out of it? It has a cheapo 6v speed 400 in it now. Just go to a speed 480 or is there a brushless engine that will do better? I would like to keep it under 100 bucks.
SC
sr batteries x250
The stock 400 motor is as 7.2V version, tied to a 2.5:1 gearbox. I changed out the 7.2V to a regular Speed 400 6V, also changed to a 1100 eight cell NiCad pack. Definitely helped in duration and slightly higher performance.
RDS
RDS
sr batteries x250
I also built the X250 and I bought everything from SR Batteries-recommended motor, gearbox, prop, 2 sets of batteries. I built it as a taildragger and it weighs 21 ounces. Mine will even take off from grass, climbs very well, loops, vertical reversals, t&g's, and stays up for more than 8 minutes (summer). The motor is a Graupner, as is gearbox and prop (9x5) and is has a Jeti ESC. I used an FMA rcvr, 2 s60 servos, and one Hitec S80. I've got more than 80 flights on it and am very satisfied.
Bob
Bob
NC,
sr batteries x250
So many choices in brushless motors. Check here:
http://www.hobby-lobby.com/brushless-motors.htm
