Electrafun XP Review/Thread!
#2501
RE: Electrafun XP Review/Thread!
Hey jaav.... check out these SPADS.... http://www.youtube.com/watch?v=y59I0fHsEkw
#2503
Another Delta.... I can see some combat with your sons Jetiger
What happened to your plans for a final slaute for Blinky Bill?
#2504
My new order from HK has landed[>:] Switches for the Pyro works [>:]
lots of rain and high tides has made the airfield wet, perfect condition so I dont burn the country but cant get out there...
Blinky has a destiny with fire[]....
no combats with this girl...
Time to make some cheap SPAD combates[>:]...
#2505
Got a email back about the delta I had ordered, (Tates) the stock said there was one left but they cant find it.. Wont be in untill next year....
Modified the bipe, bigger prop, engine re-sponded to tuning much better, heaps more pull and the horiz stab grew 6 inches..
Cut open the Calo after the mid air last week, Damage? needed 3 glue spots. Unlike the H9 P 51.
Bloody wind it hasnt backed off since sunday..Will fly the Bipe 20-30 knt wind wont upset it..
had a play with the FPV system...Freaky....
#2506
Did you blokes notice Hobby King is now shipping from NSW starting with a selection of planes? $15 shipping for 7kgs. This could get dangerous
#2509
ORIGINAL: fchris2
Beware boys, prices are USD even for postage, But it includes about 7 kg allowance so spend to save
#2510
Looks like only kits from the Aus HK site... no parts [:@] But from some of the reviews the delivery looks super quick I get twitchy when my stuff takes more than a week to arrive.... still waiting on stuff ordered from China HK last week.
What birds did you get jewfish?
#2512
ORIGINAL: fchris2
#2514
RIP. Blinky...
Put back together last night. Flown by a ex pilot, put into a high but recoverable bank nose 1st at WOT...way toomany pieces....he still has a smile...Prob be mounted to the bipe.. Flew her right to the limits today nealy lost it twice...
Have an OS20 to be mounted on the Mugi..
#2515
Hey guys Look at this...
My new speed racer.. OS46 10x6[X(]
and the Calmato suffered a major radio glitch just as I released the tail. Just as I started her she glitched the throtle servo was either at low or high, shutdown and checked all was well thought it was a sticky servo. I was lined up for take off at WOT the boys sent the Jetiger off and was off aswell, as soon it started doing the ground run she was out of controll, she did lift then banked hard nose down.
Cause unknown yet. But the 1st glitch was when the DF was run up and then failed as both were released. May be noise from the ESC on the Jet..
The same TX was used on the bipe with no problems...
The Viper 500 walks al over the Acro[>:]
#2516
Just checked the radio system. Dead. wriggled the power switch and it flashed. stripped the switch down and its full of smoke oiland has burnt contacts. this did leak during the week. The damage done by the dead landing last week cracked the fuse and the amount of oil soaked into the fuse was making it unrepairable, So I just filled the joints up with epoxy.
Did say this was prob going to be the last flight before the fuse breaks up mid air but it was over in 5 secs..
Bit peeved that the cam shut down at the start of this flight..Dont know why as it recorded the next 5 flights ok...
#2517
Hi guys.
Took out the EF for #2 son today.he did the take off and did a lap then the Xbox fingers came back and she hit the ground hard...She'll be OK....
Look what happened to my new bird!
#2518
Ouch! Where's the rest of it?
Not too much flying for me this weekend, but I did build and maiden my latest bird - a DIU slope soarer. Now I can still fly when it's windy
Jaav did you get your HK NSW order yet? Mine is still not here after 2 weeks.
#2519
2 weeks already! [>:] That is not good... I thought it should be measured in days as it's in NSW... I was thinking of getting some 4 cells... maybe I will get them from the US.
#2520
The ones I wanted were sold out when I ordered them. gave up waiting so they are coming from HKong.
the Viper. This whats left. The engine has been cleaned and is soaking in ATF to stop the rust untill its striped. The crank case is split you can see it starting from the carby mounts..Like the aileron servo being pushed through the wing.
http://www.youtube.com/watch?v=E92vojlbOdI
#2521
Rowdy I think others are getting their orders in good time. Mine had two planes so I had to pay an extra $15 postage (after the order). After a week they sent a dispatch email but nothing showed up. Now NSW warehouse don't think they did send them but they dunno for sure. Total stuff-up. Compare to my eflypower DIU DLG ordered from China last Monday night and on my doorstep Friday morning!
#2523
ORIGINAL: jewfish
I bought a boat and took 4 days to victoria............wasnt home when it arrived so postie left it at front door, god only knows how long it sat there[]
In a cople of day i should be posting pics my first 2 spad attempts.
1 is a spadbrid.......so called coz i used a plastic glider body
and finally got around to finishing the 26cc spad.
#2524
Hi All....
I was planning on building a big wing for my ElectraFun out of foam board the other night something around 1.5 meters.... but while I was digging around for stuff I came across two old EF wings that I had retired due to folded wingtips. (My current EF wing has a thin carbon fiber strip from tip to tip so wing folds are no longer a problem).... anyway, it turns out the folds were on opposite sides of each wing, so I cut off the offending bits and gluded the two together, much quicker and easier than me building a wing from scratch. The wing is now 1.6 meters from tip to tip.
I have also changed the motor on this EF, previously I had an outrunner mounted inside the fuse, but I wanted to try a different motor so I have now made a wooden bulkhead inside the fuse and can now mount the outrunner on the outside. It's much more solid now and dont get the vibrations that I used to. I will post a couple more photos when I get a chance.
http://www.youtube.com/watch?v=4Z0sEWp9LSI
#2525
Rowdy, that's great! It looks like it flew well. Nice camera work and commentary as usual. So did it feel much different to fly?
