F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
#2301
RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
Please help!
I have been flying the pz fw190 for about 12 months now and am getting bored with it. I want a Stryker c but over here in the UK it is only available without the radio! I cant import a RTF one because they all seem to be on 72mhz radio but it must be 35mhz for use in the UK! My question is can i use my heli radio for the Strykr c? it has a V-tail mode but i am not sure if that is suitable [sm=confused.gif]
All advise welcome
Thanks Ian.
All advise welcome
Thanks Ian.
#2302
Hi fellow Brit! First off, wot TX do you have (don't worry about mixing,you can get a V-tail mixer from Robotbirds for only Β£2!!). The "C" over here needs the TX and RX to match (not sure about esc?) and obviously Lipo (recommended 2100-2200 Mah 3S). Wot do you get - a F27b with stronger elevons, stronger better motormount and excellent b/less and great paint job!! OR you could go the other route to the Very dark Side- get a fuse and n/cone Β£15, good servos, carbon tube strengthen it (all tips with pics are here, see Critterhunter and Somegeeks excellent notes), your choice of b/less, esc etc. Ventillate fuse, smooth and paint to finish!!! Easy. The choice is yours but I can put one in the air for about Β£120 plus or minus Β£10. I know the educated ones here might disagree on some points but these are just personal views - just enjoy whatever you get!![8D][>:] There seems to be a growingnumber in UK going route two_Maxamus, me, and about 5 others at least[X(]
#2303
NC
I.C.O.N. ,
It looks like that (3700-3S) battery would be good for 110MPH easy if not more depending on your future motor.
From the specs that I read here ( http://www.vampowerpro.com/ ) you should be able to fit it in a 3S or 4S after cutting enough foam.
With 4S the weight of wooden Elevons would be mandatory for C.G. and you should get to 120-125+ with the right combination.
Although the 3700-5S could also fit, I would not go bigger than 3300-5S due to weight.
_______________
eeeclaire69,
V-tail and Delta are not the same. To find out more about your Heli radio you may want to place a post in the Radio forum ( http://www.rcuniverse.com/forum/forumid_157/tt.htm )and let them know that you need to know if it works with DELTA configuration for ELEVONs.
Have a great weekend everyone.
Gryphon
_______________
eeeclaire69,
Gryphon
#2304
CA
Catastrophe stricken Stryker_Viking regret he didn't buy that homing device someone mention a couple of weeks ago...
I'll never start flying again without the glasses on my nose...
Was out flying from the top of that hill where Gryphon and I were a while ago, but this time I actually managed to fly beyond my old eyes capacity...
All of a sudden my Stryker was impossible to see in the sky...
Turned co-pilot on, attempted to turn left + up elevator... throttled up... could here that Medusa scream for a second or two – then silence...
Spent two days searching and putting up posters, no luck so far...
Why didn't I get that device, would have paid off now...
I'm soo bummed...
Anyone know the source for that device?
Stryker_Viking
PS. Gryphon: Hope you are doing well over there buddy. Hey, I think you mixed it up my friend; V-tail and Delta works the same way, same settings (mix) as we use...
I'm soo bummed...
Stryker_Viking
#2305
MN
Gryphon,
Would I be better off (or just as well off) to put 2 DNpower 3S 2150's in series?
They Weigh 167g each. So I would have a 4300 3S at around 435g. They are 20C too. [link=http://www.rcgroups.com/forums/showthread.php?t=691032]They have a deal going on those 2 for $80!!![/link]
I am currently using those on all my planes (Extra,Typhoon and Stryker) They are very handy and I would love to prop up for speed or just prop down and throw one batt in for some relaxing glide time.
What do you thinks?
Thanks!
Andy
What do you thinks?
Thanks!
Andy
#2306
NC
Stryker_Viking,
I am so sorry my friend that is truly sad news. At least I wished that you could find the wreck and get partial credit for parts replacement. I hope you didn't have the Castle Creations ESC in there. Which battery was in there?
Be glad you didn't do that extra 10 hours of work you had planned for the fuse, but you must of still had an extra 10 hours compared to me.
Take that new fuse that I gave you before leaving California and get back in the air ASAP. Make sure the wings are fully straight before you do your C.F. work. Go with C.F. rods this time to get back in the air ASAP. Then take your time for the Ultimate Fuse work on the next one.
I know how you feel, for a reminder read my MEGA-Zilla thread on page 18 or 19 of park flier forum. My feelings were well documented.
I must go now.
_______________
I.C.O.N., (2) 3S in series will make 6S, but (2) 3S in parallel will give you 3S but twice capacity and amp rating. One of the Stryker gods was not so happy with me after my wreck and I was using (2) 5S-2100 in parallel for 5S. If you are not pushing the batteries to the max you'll be O.K. Also one of my best friends pushed (2) 2100-3S (15C) in parallel well into their burst rating and he had no issues. So I don't know what to say.
To be safe I will not go cheap with the battery, but I know it is a lot safer to use (2) batteries in series if it fits the application compared to (2) batteries in parallel.
_____________
As I recall my trans has a setting for V-tail and also a setting for Delta. So I'm not so sure that they are the same. I must admit that I have not had a V-tail plane in the past.
See what others with more experience in this area say; that is why I gave the link for the Radio forum on RCUniverse.
Gryphon
I must go now.
_______________
_____________
Gryphon
#2307
Hi, thanks for your reply and advise. The transmitter that i have is just the basic 6 chanel e-fly set that comes with the minipred 3d heli, it does have a v-tail mode! is v-tail suitable for the Stryker? or does it have to be delta? or are they the same?
Cheers Ian.
Cheers Ian.
#2308
Not sure, you need tomake some more enquiries. Another alternative to keep price down a lot, still golipo but use stock 480motor,(brushed esc as well)- will save about Β£45. Going on hols to Spain in 2 hours solast post for 2 weeks. Hasta la vista mi amigos, I'll be back!![>:][>:]
#2309
MN
The V-tail mixing still uses Ailerons and mixes the rudder and elevator.
Elevon mixing mixes the elevator and ailerons.
You need elevon mixing for the Stryker. There may be a way to make it work... but not without some work.
When you think about it though CCPM mixing is very close to elevon mixing on the two aileron servos. When you push forward they both go one direction and when you pull back they go the other way. So really all you would need to is use those two channels and the throttle channel for elevon mixing. You would need to work out the throws for the elevator though. Your Pitch curve would have to be set and 50% across the board. That way the elevator would not move with the throttle. The throttle curve would be a 0-100.
I think the problem would come in when you try and get more elevator throw and keep the same aileron throw... I don't believe it will support that.
I thought about this when I was tinkering with a Heli 4-in-1 unit and was going to put it in a foamy for the fun of it. Never actully got around to that one though. Although people have succfully used Blade CX 4-in-1 units for elevon foamies. So I know it can be done.
Your best bet would be to get a radio that supports both helis and all the standard mixes. But if you do try and get the mixing to work with your current radio(an I know I would have to try... ) Let us know how it turns out!
Good Luck!
Andy
Good Luck!
Andy
#2310
IN
I am using a 6 channel radio. As long as it has v tail mixing it will work.
I had a 4 channel radio with no v tail mixing and it would not work.
#2311
Does anyone know for sure (or close) what the stock BL motor's KV rating is? I want to replace my stock one and keep it slower for training my kids on a speedier plane. The stock shaft bent a bit on my last outting.
Gryphon- I am still waiting for some parts from Randy and fuses to get back in stock. I missed the last opportunity by hours. Hoping to get this built soon but everything is working against me right now.
#2312
NC
Mr. Mugen,
If you look on the right column of the link below, you'll see 1880KV.
http://www.parkzone.com/Products/Def...ProdID=PKZ4200
I'll send you a PM
_____________________
www.parkzone.com I see some new planes on there.
_________________
Gryphon
I'll send you a PM
_________________
Gryphon
#2314
PA
Hey all, haven't been on much lately. Wanted to post this great review of the $32 3500 k/v motor I was talking about a while back.
http://www.rcgroups.com/forums/showt...42#post7536847
#2315
KS
I'm looking for a bit more cheap speed on my stock (except for a Spektrum AR6100) F27c. Does anyone have any idea how many amps a 5x5 or a 6x5.5 would pull? I'm using hexTronik 2200 mAh 20/30c 3s lipos and have mounted the esc with its heatsink sticking though the fuselage cover so I'm willing to push the amps a little.
I had planned on some major motor, battery, and esc upgrades the but bought a DX7 and new charger instead.
#2316
I just put a 2200 20c in mine with a 5x5 and it drew 17.6AP and 195WP.
I just put the 6x5.5 on and came up with this....277WP and 26.05 AP WOuld need to dial it down a bit or get better esc to handle it for any duration and still be safe.
#2317
Hi guys. Gorilla Glue or CA? Which one is best? Also, I've just done a beer can mod on my Stryker on the motor mount area, and was wondering should I glue all of the metal down or just a bit of it? At the momemnt I'm thinking just glue the edges of the cans down, but that would mean the main support is still coming from the four screws going through the tin can plating and the fuse.
#2318
KS
ORIGINAL: Mr. Mugen
Have you flown with either of them? If so, what improvements? How much speed was gained and thrust lost with the 5x5? 6x5.5?
#2319
PA
ORIGINAL: robertdownes25
#2320
Sorry..... those were static not in flight. I suppose I should have mentioned that [] I bet it will be around 24ish in flight.
I have not flown with anything other than stock prop so far. I hope to tomorrow if the weather cooperates.
Hey Gryphon....I have all the pieces in my hands now. Just need to relook at the pics you sent me and start building. This is my maiden weekend for the charter boat so I will be very busy getting it ready and doing some prefishing. Maybe next week I will get started on it....hopefully.
#2321
ORIGINAL: Stryker_Viking
Mr. Mugen
Allow me to answer that question for my friend Gryphon who just moved from California (temporary we hope) to the East coast yesterday, so I think it's going to take a while before he has moved in and has his computer set up.
Gryphon and I split a batch of 100 pairs of 6 mm gold plated connectors developed and manufactured by Neu motors in San Diego, http://www.neumotors.com/20061222/Connectors.html,
We have the version for soldering to up to 10 gauge wires, (lower left on the first image)
They also have smaller connectors as well; 5.5 mm and 4.0 mm for up to 100 Amp... though they are much longer compared to the very compact 6 mm. Total length of 4 mm is 27.35 mm/1.077" long...
Remember that a chain isn't stronger then it's weakest link - use same type connectors on battery AND motor side of the esc...
Good luck
Stryker_Viking
ORIGINAL: Mr. Mugen
Gryphon-I have been looking for the post where you told us what connectors you used from the esc to motor. I think I remember them being 6.5mm? I am looking for some with no luck. I got the 125 esc today and the 16/25/2 mega. Thanks
Good luck
Stryker_Viking
just dont reduce it too much!
for instance 3mm Battery Connectors.. 2mm Motor/ESC Connectors
4mm Battery connectors.. 3mm Motor/ESC Connectors Etc..
assuming that you use the weakest link theory i hope your flooring boards are made up using 8 inch x 4 inch thick wood
forgive me if this sounds very precise.. i do drop in and often read !
why put more emphasis on connectors then slap in a cheapo Lipo?
the greatest resistance is in the Cells !
#2322
MN
ORIGINAL: critterhunter
Andy
#2323
CA
ORIGINAL: DepronJet
using common logic.. if you have 2 connections from the battery and 3 connections to the motor then the amps input will be spread over the output so you can reduce the size of the wires/connectors if you wish!
Mr. Mugen
Good luck
Stryker_Viking
ORIGINAL: Mr. Mugen
Good luck
Stryker_Viking
Hello there DepronJet...
Curiosity (as usual) drives me to ask you about your posting as it does not make sense to me...
How did you figure that one out, that..."the amps input will be spread over the output..."
My memory of the law of physics might be inaccurate and not very precise, but I have a hard time to understand your statement... also have to disagree with your recommendation to the folks here about reducing wires and connectors...
There are several of us here who experienced the consequence of overloading our too small connectors, especially when using the bigger TP extreme's...
What are you using your self (battery/motor/esc. etc.) and what is your experience with them?
Hev a great day
Stryker_Viking
* PS. ~~DO NOT reduce the size of the wires/connectors~~ *
#2324
SC
Hey Dupron
Please forgive viking as he doesn't know your vast backgrd.
Be gentle oh great master!!!
CP
P.S.
Viking
D.J. started the whole Stryker craze on here. Be careful on your messages
CP
CP
P.S.
Viking
CP
#2325
PA
ORIGINAL: I.C.O.N.
I just ordered one of these. Hope to get it in the air next week!
Andy
Andy
