GWS P-51 1047 Prop
GWS P-51 1047 Prop
Is the only problem in using this prop with the stock "C" gearbox drawing a high amperage from the battery and heating it up? Because I have an 1850mah 9.6v AA pack (which should be able to take a higher draw, right?) and EP1047, and was thinking of using them together for some faster paced flights. Anyone have an insight for me here?
I've flown it before with the stock prop, and it was do-able, but was still too tough to be fun. I'm hoping with the larger prop it will have enough thrust to make it perform well.
