first ever flight today-slow stick
UT
I have never flown an RC plane before today. I bought the slow stick about 3 days ago and built it exactly like the instructions say, except I used standard sized servos and receiver. There was about 8-9 mph wind, but I couldn't wait.
Wow, it was awesome. I was nervous about going without any experienced help, but I have used FMS for a few hours, and I had no problems today.
The landing gear is cheap. My run times with 7.2/600mah nicad were quite short. I could do loops in the first few minutes up in the air, but after that it wasn't possible.
Lots of fun
any advice would be great
Lots of fun
CA
Re- "Landing gear are cheap"
I assume you really are referring to the wheels that came with the kit, the LG are not too bad.
A lot of people have replaced them with wheels that have foam tires available from several places or your LHS. I got mine from NE Sailplanes on the Internet.
The stock wheel spokes will break easily. Also saw a post where someone had used clear packing tape over both sides of the spokes as a reenforcement. Neither CA or epoxy glues will work on the plastic spokes when they break. Someone mentioned that Goop does work.
I added an additional wire running between the "V" of the landing gear about half way up after I started running an 8 cell 1100 mah battery pack... extra weight puts more stress on the LG. This helps to prevent the "spreading" of the V in the LG.
The SS is a great plane, especially for $35.
Sierra
Sierra
pcpacker - welcome to electric flying.
Great news on the maiden of the Slow Stick. www.nesail.com has replacement wheels that really work good on the stock wire. I have them on my SS's. To get MUCH better performance, get a set of 8 cell 720 NiMH batteries. 12 - 15 min flights with loops easily all through the flight. Also it will climb easily at a 45* angle with these batteries. They run about $35 at the LHS's.
Rob
also check out www.ezonemag.com for more info. Dedicated E-Flight site.
Rob
UT
I am up in Farmington. I love my slow stick, but I am excited to move up to ailerons. I flew with a guy who had a pico stick today. Great plane. I can't decide if my next plane should be a gws p-51 or a wattage crazy max.
