E Flite Gypsy EP
E Flite Gypsy EP
Anyone flying this plane? First flight tonight and I'm not sure why the plane wont stop climbing...even with full elevator down? I have a park 370 outrunner on it and running a 10 X 4.7 prop. Any suggestions?
What have your exp been with the flight characteristics of this plane? Thanks.
NC
RE: E Flite Gypsy EP
Check for a warped elevator and horizontial stabilizer. My Girlfriend's will fly that way too. We had to heat the covering alot to get it tight. I think I will be adding nose weight.
Jim
Jim
also check your CG as you might be a bit tail heavy, also reset your elevator trim by shortning the clevis at the evelator end that would give you more down trim
