Battery for wingo
Battery for wingo
I just got a wingo from hobby lobby, my first working electric.
Im going to get the gear drive for it , anyone suggest which battery to use? I got a 7cell 600mah with the plane .but from what i have read you should go to a bigger battery when you use the gear box. but which one? or even a different battery than I have know to get longer flight times from it with out the gear box would be nice.
guess i just dont understand why you can go to more cells which will increase the voltage, when using the same motor which is a speed 400
thanks
thanks
